After I use -Minfo , there is a output: # pragma acc for parallel, the vector (256) / * blockIdx.x threadIdx.x * /
For this output, What does 256 means? How do you know the compiler allocates a block and how many threads allocated for each block ?
It’s the vector width and translates into CUDA as the thread block size. “parallel” translates to CUDA as the block. So in this case you have a 1-D Grid containing a 1-D Block containing 256 threads. Since “parallel” does not have a width, the number of blocks launched will be determined dynamically at run time depending upon the size of the loop.
This indicates the exact CUDA dimension being used.
Hope this helps,
Mat
Thanks a lot.
