About new option -ta=multicore
PGI compiler, code with openacc directives.
I wonder how many cores it used and
if can I set how many cores it used?
About question 1
I have 2 multicore(6 cores) cpus. -ta=multicore option will utilize 6 or 12 cores?
I think your questions are answered here:
[url]http://www.pgroup.com/lit/articles/insider/v6n3a1.htm[/url]
“You can control how many threads the program will use to run the parallel compute regions with the environment variable ACC_NUM_CORES. The default is to count how many cores are available on the system. For Linux targets, the runtime will only count physical cores (not hyper-threaded logical cores), and launch that many threads.”
On a dual-socket system with 6 cores per socket, -ta=multicore should use 12 cores.
Thank you very much.
