Is it possible to use
or
NGC containers with xavier?
or
These are for amd64 architecture containers. You can search with “l4t” tag from here:
https://ngc.nvidia.com/catalog/containers?orderBy=scoreDESC&pageNumber=0&query=l4t&quickFilter=containers&filters=
I think, you can use
instead of nvcr.io/nvidia/tensorrt:xx.xx-py3
and
instead of nvcr.io/nvidia/tensorflow:xx.xx-tfx-py3
I have never tried it before yet, but these should work.
Hope it helps.
That’s correct, you should use the l4t-* containers on Jetson. Also the TensorRT/CUDA/cuDNN are already mounted into l4t-base.
The l4t-pytorch, l4t-tensorflow, and l4t-ml containers are built from here if you wish to customize them: GitHub - dusty-nv/jetson-containers: Machine Learning Containers for NVIDIA Jetson and JetPack-L4T
