About NvEglRenderer with z-order of window
Looking at NvEglRenderer.h
It appears that creating an EGL context while creating a window using X and rendering through EGL.
If you explain 00_video_decode as an example
When the screen is playing, the window’s z-order is almost at the top, hiding other things.
How do you approach this z-order adjustment?
========= NvEglRenderer.h ===============================
I left a lot of questions.
If the corona situation calms down and you have a chance to come to Korea, call me and I will buy you a drink. :)👍
Thank you.
For rendering multipe sources, you can create multiple NvEglRenderer and configure different width, height, x_offset, y_offset. Not to overlap other sources.
We have a player using qt.
By making certain areas transparent in the program
I want to show what EglRenderer draws
Should I check Xlib programming for z-order?
Thank you
Yes, you would need to use X APIs for the function. Maybe need to configure certain attributes in XCreateWindow():
