Dear Sir,
We would like to use NXP SC16IS741A(I2C to UART) to get the additional UART interface.
L4T:28.2.0
CONFIG_SERIAL_SC16IS7XX=y
CONFIG_SERIAL_SC16IS7XX_I2C=y
Driver Path: /kernel/kernel-4.4/drivers/tty/serial/sc16is7xx.c
This is my final device tree setting
i2c@7000c000 { sc16is741: sc16is741@48 { status = "okay"; compatible = "nxp,sc16is741"; reg = <0x48>; interrupt-parent = <&gpio>; interrupts = <TEGRA_GPIO(K, 4) IRQ_TYPE_EDGE_FALLING>; #interrupt-cells = <2>; interrupt-controller; gpio-controller; #gpio-cells = <2>; vcc-supply = <&battery_reg>; }; };
After booting,
[ 0.503552] <0> [sk]sc16is7xx_i2c_probe irq=0x91: check 0x91
[ 0.503714] sc16is7xx: probe of 0-0048 failed with error -2
=> I got a error at the probe stage.
After debuging,
static int sc16is7xx_probe(struct device *dev, const struct sc16is7xx_devtype *devtype, struct regmap *regmap, int irq, unsigned long flags) { struct sched_param sched_param = { .sched_priority = MAX_RT_PRIO / 2 }; unsigned long freq, *pfreq = dev_get_platdata(dev); int i, ret; struct sc16is7xx_port *s; printk("<0> [sk]sc16is7xx_i2c_probe irq=0x%x: check 0x%x\n", irq, gpio_to_irq(84) ); if (IS_ERR(regmap)) return PTR_ERR(regmap); printk("<0> [sk] regmap ok\n" ); /* Alloc port structure */ s = devm_kzalloc(dev, sizeof(*s) + sizeof(struct sc16is7xx_one) * devtype->nr_uart, GFP_KERNEL); if (!s) { dev_err(dev, "Error allocating port structure\n"); return -ENOMEM; }
static int sc16is7xx_i2c_probe(struct i2c_client *i2c,
const struct i2c_device_id *id)
const struct sc16is7xx_devtype *devtype;
unsigned long flags = 0;
struct regmap *regmap;
regcfg.max_register = (0xf << SC16IS7XX_REG_SHIFT) |
(devtype->nr_uart - 1);
regmap = devm_regmap_init_i2c(i2c, ®cfg);
return sc16is7xx_probe(&i2c->dev, devtype, regmap, i2c->irq, flags);
=> The error is from
When I use the i2cdetect command, I can see the hardware at 0x48 address of I2C bus 0.
Can you help me this issue for regmap? or Any suggestion?
