About Profiling frontend sample in mmapi
After disabling ENABLETRT in Makefile and disabling filewrite in VideoEncoder.cpp, I am testing encoding while driving the frontend sample for a long time.
  1. I was using the free program of linux to monitor the memory usage, and it was confirmed that the free memory continued to decrease.
    Is there a memory leak in the frontend sample or libargus?
  2. Currently, only free memory is checked using free.
    Is there a slightly better profiling method?
Thank you.
You can run top to check the memory of the process. See if it increases in long run.
Do you hit OOM killer if you run a long run test? Which release do you use?
