Can I know the address of the framework or GitHub project that learned the onnx file of the 04 sample in the 32.5 release?
Can you tell us the learning framework or GitHub project address you used for the onnx file of the 04 sample in the 32.5 release and the onnx conversion code (torch.onnx.export) you used?
in the trt_inference.h file
I am trying to fill in the gModelNetAttr structure, but I am not sure, so I am trying to use it as it is after learning and transforming it through the framework used to create the sample model.
Thank you.
