When I downloaded raw data of kitti’s velodrone,
(Download)
And tried to read this in the dw accumulator,
$ ./sample_lidar_accumulator --device=VELO_HDL64E --file=[DOWNLOAD]/data/testing/velodyne/0028/000134.bin
Driveworks exception thrown: DW_FAILURE: LidarVirtual: unknown lidar type
but it does not seem to support it. Is that right?
Could you please refer to page 11(Supported Sensors) in DriveWorks DevGuide.pdf file?
DPX2 support Velodyne (VPL16, HDL32E, HDL 64-S3).
I’m not sure kitti’s velodyne data you mentioned used VELO_HDL64E or not. Thanks.
I still use the sample code without actually connecting to drivepx2. The Lidar Accumulator Sample README states that 64E is supported as shown below.
#### Running the Sample
The command line for the sample to run with live Lidar sensor is:
./sample_lidar_accumulator --ip=[Lidar IP address] --port=[Lidar port]
--device=[type of device] --scan-frequency=[valid frequency]
--mode=[sync or async]
--maxDistance[max distance in meters to select the Lidar points]
--minDistance[min distance in meters to select the Lidar points]
--minAngle[min angle in degrees to select the Lidar points]
--maxAngle[max angle in degrees to select the Lidar points]
--smooth-window-size[1, 2, 4, 8]
--lidar-image-type[depth-xyz, depth-xy or intensity]
- The Lidar must be connected to the network.
- Currently supported devices are Quanergy M8 [QUAN_M81A],
Velodyne VPL16 [VELO_VPL16], Velodyne HDL32 [VELO_HDL32E] and Velodyne HDL64E [VELO_HDL64E]
