【movie capture-path trace samples per pixel】 and 【render settings -totalsamples per pixel】
What is the relationship between the two parameters。
Who controls the final rendering quality
Hi @312436941 ,
They have no relationship in that the render settings-total samples per pixel under render settings tab only apply to viewport rendering/previewing. Movie capture-path trace samples per pixel settings is for when you are using the movie capture to render out the output, it is not affected by the total sample per pixel under render settings tab, but other settings like bounces etc. do affect the final output for both.
Thank you O(∩_∩)O
