Hello, there are several modes configured for the sensor in my dts, but when I want to use it, it tells me that I do not have sensor_mode, thank you
Did you add use_sensor_mode_id = “true”; in your device tree?
You can reference to imx185 for it.
What’s the v4l2-ctl --list-formats-ext?
How about v4l2-ctl --set-ctrl sensor_mode=1?
Why there are duplicate format and size?
emmm, I also wonder, is this a device tree configuration issue?
Suppose need to check the sensor driver.
Hello ShaneCCC,
May I ask which part I should check? I have consulted imx185 and found no problem.
I believe it’s report by the kernel driver.
hello ShaneCCC,
i use 35.5.0, I should refer to nv_imx185_v1.c or nv_imx185.c
Should be nv_imx185.c or nv_imx477/nv_imx219
Maybe remove the duplicated sizes to try.
thank you, its right.
