Hi:
Can anyone check some parameters for me? thanks.
The csi2 lane speed is 350Mbps/lane, HS byte clock is 43.75Mhz . the camera's output is 1280*800@48 .
so at the dts file:
mode0{
mclk_khz = "43750"; // 43.75Mhz
mclk_multiplier = "2.05"; // 49183745/24000000 = 2.049
pix_clk_hz = "49183745"; // 1280*800*48.031 = 49183745
The mclk_khz is a static parameter ? It will always be "24000" ? After read some of camera's dts file ,I found that the mclk_khz always be "24000".
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* mclk_khz = "";
* Standard MIPI driving clock, typically 24MHz
so,the mclk_khz is the input frequency of sensor,NOT the output of sensor’s mipi-csi frequency.
and,at the drivers/media/i2c/imx185.c,line 62,there is a macro: IMX185_DEFAULT_CLK_FREQ. The mclk_khz just equals the IMX185_DEFAULT_CLK_FREQ ?
Specifies the multiplier to MCLK for timing the capture sequence of the hardware. Use the following equation to calculate this value:
mclk_multiplier = desired ISP clock frequency / mclk.
This value must be larger than pixel_clk_hz / mclk to prevent ISP underrun.
As we know, mclk is 24Mhz .So if I want to let the HS byte clock which at tx2’s csi to be 43.75Mhz,I just set mclk_multiplier to “1.823” ??? 43.75/24=1.82291666 .
HS byte clock is just another form of lane speed(high speed mode).
The unit of lane speed is bit per second,and the unit of HS byte clock is byte per second.
lane of speed = HS byte clock * 8
If the lane speed is 350Mbps/lane,and the HS byte clock will be 350/8=43.75Mhz.
Pixel of our ar0134 is 60Mhz,the output is parallel(raw8),we use tx358748xbg to translate data from parallel to mipi-csi,there have 2 lanes. And the suitable data output frequency of tx358748xbg should be 480Mbps/s( 60Mhz*8) . Each lane speed should be 240Mbps/s( 480/2) . The suitable Hs byte clock of tx358748xbg is 30Mhz (240/8) .
