Hi,dear support team
After some attempts ,I was finally able to get the data of the 2x3trios camera.
as follows:
smartsens@smartsens-desktop:~/Downloads$ cat /dev/video0
�D����D���D�DDDD������D��������D����D������D��D�D��D��DD�DD�D������DD���D�D�����D�D�D���D����D������DDD��D�D�...
But the VI module seems to keep reporting errors, and I cannot get images through v4l2-ctl command:
[ 1153.983721] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 38632 vs ch1 38543
[ 1153.992957] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1154.004477] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1154.012196] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1154.022852] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1154.030571] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1154.041144] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1154.048841] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1154.059494] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1154.067190] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1154.078071] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1154.972406] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1154.984928] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffea62e00, fsynr=0x5c0010, cbfrsynra=0x804, cb=1
[ 1155.001219] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1155.010082] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1155.016965] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1155.025206] mc-err: secure: yes, access-type: write
[ 1155.030451] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 38662 vs ch1 38574
[ 1155.039706] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1155.051522] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1155.059245] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1155.069949] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1155.077654] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1155.088240] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1155.095951] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1155.106621] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1155.114304] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1155.125158] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1156.166682] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1156.175584] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1156.182494] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1156.190735] mc-err: secure: yes, access-type: write
[ 1156.196036] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 38698 vs ch1 38609
[ 1156.205264] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1156.216511] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1156.224222] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1156.234877] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1156.242578] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1156.253144] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1156.260849] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1156.271487] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1156.279194] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1156.290042] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1157.236724] arm_smmu_context_fault: 5495 callbacks suppressed
[ 1157.236729] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1157.255094] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffef485c0, fsynr=0x5c0010, cbfrsynra=0x804, cb=1
[ 1157.267550] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1157.276405] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1157.283297] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1157.291532] mc-err: secure: yes, access-type: write
[ 1157.296858] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 38730 vs ch1 38642
[ 1157.306144] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1157.317509] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1157.325266] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1157.336002] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1157.343731] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1157.354331] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1157.362042] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1157.372705] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1157.380419] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1157.391284] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1158.402191] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1158.414686] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffea60d80, fsynr=0x5c0010, cbfrsynra=0x4, cb=1
[ 1158.426953] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7fff4a2ac0, fsynr=0x5c0010, cbfrsynra=0x404, cb=1
[ 1158.439415] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1158.448274] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1158.455177] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1158.463413] mc-err: secure: yes, access-type: write
[ 1158.468721] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 38765 vs ch1 38677
[ 1158.477979] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1158.489506] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1158.497241] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1158.507924] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1158.515662] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1158.526277] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1158.534015] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1158.544713] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1158.552453] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1158.563295] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1159.434467] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1159.446978] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffea644c0, fsynr=0x5c0010, cbfrsynra=0x4, cb=1
[ 1159.459253] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7fff4a6940, fsynr=0x5c0010, cbfrsynra=0x4, cb=1
[ 1159.471554] mc-err: Too many MC errors; throttling prints
[ 1159.478210] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 38797 vs ch1 38708
[ 1159.487493] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1159.498486] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1159.506217] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1159.516903] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1159.524634] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1159.535214] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1159.542944] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1159.553613] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1159.561342] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1159.572201] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1160.633220] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1160.645719] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffea5ef40, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1160.662024] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1160.670886] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1160.677794] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1160.686021] mc-err: secure: yes, access-type: write
[ 1160.691291] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 38832 vs ch1 38744
[ 1160.700545] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1160.711494] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1160.719210] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1160.729872] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1160.737589] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1160.748157] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1160.755869] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1160.766502] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1160.774205] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1160.785078] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1161.594423] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1161.603335] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1161.610252] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1161.618489] mc-err: secure: yes, access-type: write
[ 1161.623816] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 38861 vs ch1 38772
[ 1161.633069] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1161.644503] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1161.652215] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1161.662874] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1161.670585] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1161.681156] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1161.688860] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1161.699514] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1161.707218] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1161.718122] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1162.431359] arm_smmu_context_fault: 5589 callbacks suppressed
[ 1162.431365] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1162.449730] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffef46ac0, fsynr=0x5c0010, cbfrsynra=0x804, cb=1
[ 1162.462200] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1162.471057] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1162.477964] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1162.486199] mc-err: secure: yes, access-type: write
[ 1162.491424] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 38886 vs ch1 38798
[ 1162.500646] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1162.511497] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1162.519206] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1162.529862] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1162.537577] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1162.548123] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1162.555828] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1162.566478] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1162.574177] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1162.585036] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1163.330436] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1163.342920] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffea5ea80, fsynr=0x5c0010, cbfrsynra=0x404, cb=1
[ 1163.355345] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7fff4c2c40, fsynr=0x5c0010, cbfrsynra=0x804, cb=1
[ 1163.367788] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1163.376656] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1163.383552] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1163.391787] mc-err: secure: yes, access-type: write
[ 1163.397084] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 38913 vs ch1 38825
[ 1163.406303] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1163.417501] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1163.425207] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1163.435855] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1163.443566] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1163.454132] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1163.461841] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1163.472490] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1163.480194] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1163.491044] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1164.229508] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1164.241968] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffea5cb80, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1164.254395] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7fff4bc380, fsynr=0x5c0010, cbfrsynra=0x4, cb=1
[ 1164.266664] mc-err: Too many MC errors; throttling prints
[ 1164.273154] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 38941 vs ch1 38852
[ 1164.282385] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1164.293477] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1164.301180] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1164.311829] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1164.319545] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1164.330121] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1164.337824] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1164.348472] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1164.356187] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1164.367033] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1165.361673] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1165.374153] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffea5cac0, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1165.390475] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1165.399339] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1165.406245] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1165.414485] mc-err: secure: yes, access-type: write
[ 1165.419781] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 38974 vs ch1 38886
[ 1165.429011] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1165.440508] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1165.448215] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1165.458865] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1165.466566] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1165.477158] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1165.484857] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1165.495509] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1165.503211] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1165.514046] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1166.555939] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1166.564829] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1166.571733] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1166.579981] mc-err: secure: yes, access-type: write
[ 1166.585270] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39010 vs ch1 38921
[ 1166.594497] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1166.605500] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1166.613210] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1166.623853] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1166.631568] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1166.642140] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1166.649833] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1166.660486] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1166.668180] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1166.679039] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1167.592701] arm_smmu_context_fault: 6453 callbacks suppressed
[ 1167.592714] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1167.611112] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffef4ce80, fsynr=0x5c0010, cbfrsynra=0x804, cb=1
[ 1167.623626] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1167.632532] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1167.639463] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1167.647717] mc-err: secure: yes, access-type: write
[ 1167.653030] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39042 vs ch1 38953
[ 1167.662266] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1167.673502] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1167.681206] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1167.691856] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1167.699571] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1167.710123] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1167.717828] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1167.728476] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1167.736182] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1167.747025] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1168.525073] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1168.537547] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffea5e380, fsynr=0x5c0010, cbfrsynra=0x4, cb=1
[ 1168.549822] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7fff49ef00, fsynr=0x5c0010, cbfrsynra=0x804, cb=1
[ 1168.562266] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1168.571129] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1168.578030] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1168.586272] mc-err: secure: yes, access-type: write
[ 1168.591544] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39070 vs ch1 38981
[ 1168.600806] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1168.611488] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1168.619290] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1168.629963] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1168.637671] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1168.648223] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1168.655929] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1168.666586] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1168.674294] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1168.685156] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1169.424145] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1169.436614] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffea5c6c0, fsynr=0x5c0010, cbfrsynra=0x4, cb=1
[ 1169.448857] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7fff498580, fsynr=0x5c0010, cbfrsynra=0x4, cb=1
[ 1169.461132] mc-err: Too many MC errors; throttling prints
[ 1169.467826] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39097 vs ch1 39008
[ 1169.477046] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1169.488484] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1169.496196] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1169.506859] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1169.514573] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1169.525134] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1169.532826] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1169.543459] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1169.551156] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1169.561984] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1170.456532] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1170.469033] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffea7ad80, fsynr=0x5c0010, cbfrsynra=0x404, cb=1
[ 1170.485218] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1170.494094] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1170.501001] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1170.509274] mc-err: secure: yes, access-type: write
[ 1170.514663] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39127 vs ch1 39039
[ 1170.523924] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1170.535510] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1170.543222] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1170.553888] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1170.561604] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1170.572180] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1170.579887] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1170.590535] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1170.598230] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1170.609092] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1171.317713] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1171.326591] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1171.333503] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1171.341735] mc-err: secure: yes, access-type: write
[ 1171.346977] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39152 vs ch1 39064
[ 1171.356214] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1171.367510] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1171.375232] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1171.385905] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1171.393623] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1171.404200] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1171.411897] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1171.422553] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1171.430252] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1171.441112] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1172.150181] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1172.159089] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1172.166000] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1172.174243] mc-err: secure: yes, access-type: write
[ 1172.179723] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39178 vs ch1 39089
[ 1172.188973] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1172.200513] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1172.208222] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1172.218884] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1172.226593] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1172.237161] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1172.244866] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1172.255488] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1172.263183] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1172.274074] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1172.920531] arm_smmu_context_fault: 10389 callbacks suppressed
[ 1172.920538] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1172.939011] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffef60040, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1172.951459] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1172.960350] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1172.967260] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1172.975501] mc-err: secure: yes, access-type: write
[ 1172.980877] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39202 vs ch1 39113
[ 1172.990148] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1173.001509] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1173.009217] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1173.019877] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1173.027601] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1173.038183] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1173.045898] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1173.056551] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1173.064278] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1173.075170] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1173.719716] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1173.732231] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffea60e80, fsynr=0x5c0010, cbfrsynra=0x4, cb=1
[ 1173.744500] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7fff4a66c0, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1173.756995] mc-err: Too many MC errors; throttling prints
[ 1173.762742] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39225 vs ch1 39137
[ 1173.771980] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1173.783502] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1173.791225] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1173.801885] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1173.809595] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1173.820161] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1173.827866] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1173.838517] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1173.846249] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1173.857655] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1174.485735] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1174.498273] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffea82a00, fsynr=0x5c0010, cbfrsynra=0x804, cb=1
[ 1174.510719] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7fff4f0240, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1174.523203] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1174.532075] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1174.538986] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1174.547228] mc-err: secure: yes, access-type: write
[ 1174.552599] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39248 vs ch1 39160
[ 1174.561852] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1174.573505] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1174.581209] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1174.591857] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1174.599567] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1174.610147] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1174.617846] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1174.628774] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1174.636505] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1174.647410] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1175.318059] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1175.330539] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffea60900, fsynr=0x5c0010, cbfrsynra=0x804, cb=1
[ 1175.346858] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1175.355735] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1175.362640] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1175.370887] mc-err: secure: yes, access-type: write
[ 1175.376135] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39274 vs ch1 39185
[ 1175.385384] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1175.396504] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1175.404214] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1175.414874] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1175.422589] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1175.433172] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1175.440880] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1175.451528] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1175.459250] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1175.470106] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1176.179363] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1176.188245] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1176.195151] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1176.203402] mc-err: secure: yes, access-type: write
[ 1176.208809] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39299 vs ch1 39210
[ 1176.218037] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1176.229500] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1176.237223] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1176.247894] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1176.255604] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1176.266186] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1176.273901] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1176.284556] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1176.292258] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1176.303166] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1177.244916] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1177.253797] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1177.260688] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1177.268931] mc-err: secure: yes, access-type: write
[ 1177.274184] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39330 vs ch1 39242
[ 1177.283436] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1177.294493] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1177.302215] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1177.312873] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1177.320586] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1177.331151] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1177.338852] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1177.349497] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1177.357205] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1177.368085] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1178.348259] arm_smmu_context_fault: 11929 callbacks suppressed
[ 1178.348265] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1178.366748] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffef5ea40, fsynr=0x5c0010, cbfrsynra=0x404, cb=1
[ 1178.379191] mc-err: Too many MC errors; throttling prints
[ 1178.384983] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39364 vs ch1 39276
[ 1178.394235] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1178.405517] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1178.413236] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1178.423902] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1178.431610] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1178.442206] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1178.449914] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1178.460577] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1178.468297] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1178.479165] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1179.447128] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1179.459584] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffea5c4c0, fsynr=0x5c0010, cbfrsynra=0x4, cb=1
[ 1179.471837] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7fff494fc0, fsynr=0x5c0010, cbfrsynra=0x4, cb=1
[ 1179.484105] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1179.492963] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1179.499853] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1179.508084] mc-err: secure: yes, access-type: write
[ 1179.513516] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39398 vs ch1 39309
[ 1179.522768] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1179.533513] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1179.541232] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1179.551896] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1179.559610] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1179.570187] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1179.577883] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1179.588543] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1179.596263] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1179.607133] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1180.346201] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1180.358690] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffea62600, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1180.371123] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7fff4c4e00, fsynr=0x5c0010, cbfrsynra=0x404, cb=1
[ 1180.383586] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1180.392455] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1180.399360] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1180.407605] mc-err: secure: yes, access-type: write
[ 1180.412896] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39425 vs ch1 39336
[ 1180.422125] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1180.433511] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1180.441230] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1180.451893] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1180.459609] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1180.470183] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1180.477919] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1180.488583] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1180.496312] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1180.507184] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1181.211981] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1181.224514] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffea64d40, fsynr=0x5c0010, cbfrsynra=0x404, cb=1
[ 1181.240808] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1181.249682] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1181.256584] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1181.264814] mc-err: secure: yes, access-type: write
[ 1181.270114] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39450 vs ch1 39362
[ 1181.279367] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1181.290523] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1181.298256] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1181.308910] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1181.316635] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1181.327211] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1181.334910] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1181.345566] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1181.353276] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1181.364183] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1182.073254] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1182.082127] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1182.089037] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1182.097273] mc-err: secure: yes, access-type: write
[ 1182.102560] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39476 vs ch1 39387
[ 1182.111801] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1182.123512] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1182.131231] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1182.141897] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1182.149607] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1182.160193] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1182.167913] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1182.178565] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1182.186265] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1182.197140] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1183.138830] mc-err: Too many MC errors; throttling prints
[ 1183.153779] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39508 vs ch1 39419
[ 1183.163018] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1183.174481] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1183.182195] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1183.192850] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1183.200562] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1183.211111] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1183.218793] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1183.229466] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1183.237218] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1183.248081] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1184.242179] arm_smmu_context_fault: 11175 callbacks suppressed
[ 1184.242189] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1184.260702] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffef5e2c0, fsynr=0x5c0010, cbfrsynra=0x4, cb=1
[ 1184.273018] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1184.281903] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1184.288823] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1184.297070] mc-err: secure: yes, access-type: write
[ 1184.302316] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39541 vs ch1 39453
[ 1184.311544] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1184.322533] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1184.330248] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1184.340903] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1184.348615] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1184.359188] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1184.366892] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1184.377544] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1184.385248] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1184.396072] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1185.307752] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1185.320262] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffea64940, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1185.332718] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7fff4cc900, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1185.345211] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1185.354092] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1185.360989] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1185.369230] mc-err: secure: yes, access-type: write
[ 1185.374470] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39574 vs ch1 39485
[ 1185.383710] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1185.394497] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1185.402199] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1185.412852] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1185.420560] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1185.431120] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1185.438834] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1185.449489] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1185.457197] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1185.468020] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 1186.439915] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffe000000, fsynr=0x5c0010, cbfrsynra=0xc04, cb=1
[ 1186.452435] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffea62cc0, fsynr=0x5c0010, cbfrsynra=0x804, cb=1
[ 1186.464886] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7fff4cc7c0, fsynr=0x5c0010, cbfrsynra=0x4, cb=1
[ 1186.477202] mc-err: vpr base=8:49800000, size=368, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 1186.486101] mc-err: (255) csw_vi2w: MC request violates VPR requirements
[ 1186.493016] mc-err: status = 0x0ff74070; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 1186.501247] mc-err: secure: yes, access-type: write
[ 1186.506568] tegra-camrtc-capture-vi tegra-capture-vi: frame_id out of sync: ch2 39607 vs ch1 39519
[ 1186.515809] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1186.527505] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1186.535217] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 1186.535220] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1186.535225] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 1186.564141] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1186.571855] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 1186.582513] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 1186.590233] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 1186.601126] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
please give me some debugging suggestions Thank you.
