Does Detectnet_V2 in TLT2.0 support log output during train?
Checking this thread, it said that TLT 3.0 supports this.
However, in the case of TLT2.0, learning with --log_file
will result in an error.
Is there any other way to output logs?
You can use the latest TAO container.
--log_file LOG_FILE Path to the output log file.
I know the existence of TAO.
However, I am using TLT2.0 because of compatibility with Deepstream ver.
Therefore, please tell me if there is a way to output the log file with TLT2.0.
For TLT2.0, you can try something as below.
For example,
tlt-train faster_rcnn -e spec.txt 2>&1 |tee log.txt
Thank you very much.
I was able to output the log.
