Dear Sir,
We use the camera driver in ‘L4T_R32.2.1’ to get the YUV422 (YUYV) video frame.
In the device tree, the mode is described as below:
mode1 {
pixel_t = “yuv_yuyv16”;
Use the following command to capture YUV422 (YUYV) video frames:
v4l2-ctl --device /dev/video0 --stream-mmap --stream-count=120 --stream-to=dump.yuv
Use the following command to play YUV422 (YUYV) video frames:
vlc --demux=rawvideo --rawvid-width=1280 --rawvid-height=720 --rawvid-chroma=YUYV --rawvid-fps=1 ./dump.yuv
The command could not play the video frames correctly.
But when changing “–rawvid-chroma” as “UYVY”, the command could play the video frames correctly:
vlc --demux=rawvideo --rawvid-width=1280 --rawvid-height=720 --rawvid-chroma=UYVY --rawvid-fps=1 ./dump.yuv
And then change the values of ‘enum tegra_image_format’ (nvidia/drivers/media/platform/tegra/camera/vi/vi4_formats.h)related to YUV422 :
enum tegra_image_format {
TEGRA_IMAGE_FORMAT_T_Y8_U8__Y8_V8 = 200,
TEGRA_IMAGE_FORMAT_T_Y8_V8__Y8_U8,
TEGRA_IMAGE_FORMAT_T_U8_Y8__V8_Y8 = 203,
TEGRA_IMAGE_FORMAT_T_V8_Y8__U8_Y8 = 223,
to:
TEGRA_IMAGE_FORMAT_T_U8_Y8__V8_Y8 = 200,
TEGRA_IMAGE_FORMAT_T_V8_Y8__U8_Y8,
TEGRA_IMAGE_FORMAT_T_Y8_U8__Y8_V8 = 203,
TEGRA_IMAGE_FORMAT_T_Y8_V8__Y8_U8 = 223,
The command could play the video frames correctly:
Please help me to check the issue. Thanks!
BR,
Jeff Liao
