we had fix the Nano APP partition cloning issue, which correct the failure of reading partition data from the the target device.
could you please upgrade to l4t-r32.3.1, please download the attachment, and overwrite below binary for verification.
$OUT/Linux_for_Tegra/bootloader/nvtboot_recovery.bin
thanks devtalk1064479_r32.3.1_nvtboot_recovery.tar.gz (82.6 KB)
encoder@encoder:~/Hämtningar/Jetson/Linux_for_Tegra/bootloader$ sudo ./tegraflash.py --bl cboot.bin --applet nvtboot_recovery.bin --chip 0x21 --cmd “read APP my_backup_image_APP.img”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0027 ] Generating RCM messages
[ 0.0039 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0050 ] RCM 0 is saved as rcm_0.rcm
[ 0.0057 ] RCM 1 is saved as rcm_1.rcm
[ 0.0057 ] List of rcm files are saved in rcm_list.xml
[ 0.0057 ]
[ 0.0057 ] Signing RCM messages
[ 0.0066 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0074 ] Assuming zero filled SBK key
[ 0.0130 ]
[ 0.0130 ] Copying signature to RCM mesages
[ 0.0143 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0157 ]
[ 0.0158 ] Boot Rom communication
[ 0.0167 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 0.0176 ] BR_CID: 0x321010016445c8460000000014fd83c0
[ 0.0938 ] RCM version 0X210001
[ 0.1821 ] Boot Rom communication completed
[ 1.1996 ]
[ 1.1998 ] Reading BCT from device for further operations
[ 1.1998 ] Retrieving storage infomation
[ 1.2032 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 1.2062 ] Applet version 00.01.0000
[ 1.3648 ] Saved platform info in storage_info.bin
[ 1.4490 ]
[ 1.4492 ] Sending bootloader and pre-requisite binaries
[ 1.4528 ] tegrarcm --download ebt cboot.bin 0 0
[ 1.4560 ] Applet version 00.01.0000
[ 1.6202 ] Sending ebt
[ 1.6204 ] […] 100%
[ 1.9468 ] 00000004: Verification failed
If you use the same release from which the clone is derived, and have your clone put in the “Linux_for_Tegra/bootloader/” directory with name “system.img”, then this image will be used without regenerating a new image whenever the “-r” option is used. As an example, assuming eMMC version:
This is a full flash, but will use the image in place rather than creating a new image from the sample rootfs. A lot of partitions are required for boot since embedded systems do not have a BIOS, and thus you need those other partitions…but the trick is that those other partitions are standardized, and so the real customization is the rootfs.
HI, I would like to zip the flash.sh and it’s binaries and use it to flash production module in the factory. I am trying to do following
1.Generate all the images by
– sudo sudo ./flash.sh --no-flash jetson-nano-emmc mmcblk0p1
2.zip Linux_for_Tegra without rootfs directory
3.try to unzip on another machine and run sudo sudo ./flash.sh -r jetson-nano-emmc mmcblk0p1
the script seems still looking for rotofs directory. is there any other way i can achieve this ?
[quote=“linuxdev, post:10, topic:82908”]
The dd command itself won’t care what it runs on…this command is an exact bit-for-bit binary copy without any knowledge of what the underlying data is
[/quote]sudo ./flash.sh -r -k APP -G backup.img jetson-nano-qspi-sd mmcblk0p1, but error,
hello, I want clone jetson with sd img by
[0004.728] Number of retries left 2
[0004.731] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0004.741] Command complete wait failed with error 0x3 Interrupt 0x18001
[0004.748] Number of retries left 1
[0004.751] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0004.761] Command complete wait failed with error 0x3 Interrupt 0x18000
[0004.768] Number of retries left 0
[0004.771] Send command failed with 0x3
[0004.774] CMD8 send failed. Retrying CMD0/CMD8 (0)…
[0004.779] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0004.790] Command complete wait failed with error 0x3 Interrupt 0x18000
[0004.796] Number of retries left 4
[0004.799] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0004.810] Command complete wait failed with error 0x3 Interrupt 0x18000
[0004.816] Number of retries left 3
[0004.820] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0004.830] Command complete wait failed with error 0x3 Interrupt 0x18000
[0004.836] Number of retries left 2
[0004.840] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0004.850] Command complete wait failed with error 0x3 Interrupt 0x18000
[0004.856] Number of retries left 1
[0004.860] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0004.870] Command complete wait failed with error 0x3 Interrupt 0x18001
[0004.876] Number of retries left 0
[0004.879] Send command failed with 0x3
[0004.883] CMD55 send failed with error 0x3 in SdIdentifyCard func at 1870 line
[0004.890] SD Identify card failed with 0x3
[0004.894] SdIdentifyCard has failed with error 0x3 in NvTbootSdmmcInit func at 87 line
[0004.901] Sdmmc Init failed with 0x3 error
[0004.927] Error is 3
