About the setting value of ROOTFS_RETRY_COUNT_MAX
ROOTFS_RETRY_COUNT_MAX can be set to 0-3. If I set ROOTFS_RETRY_COUNT_MAX to “0”, will Jetson immediately go to Recovery Boot when I turn on the power to Jetson? Or will it not transition to Recovery Boot?
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/SD/RootFileSystem.html?highlight=rootfs_retry_count_max%201#flashing-the-target-board-with-a-redundant-root-file-systems
Best Regards,
UNA
That means there is no re-try at all if the device fails to boot for the first time.
