About the TX2 NX ,When restart button is pressed,the system is do not startup。
I am curious about some of the details. I am impressed if you got tomcat running well, but am led to the question as to whether you might have run out of disk space (tomcat is a bit of a hog even it is a cat…yes, bad humor!). Was the system simply shut off by power button without true/proper shutdown at any point? If the file system is under heavy write at that time (such as tomcat might do), then results might not be so good.
It might be nice to get a full serial console boot log. See:
http://www.jetsonhacks.com/2017/03/24/serial-console-nvidia-jetson-tx2/
