We found a description of MGBE in the document <Jetson_Thor_Series_Modules_DesignGuide_DG12084001_v1.5>. We would like to confirm whether it is possible to use a 10G PHY, such as AQR113C, on MGBE0 when connecting two REFCLK clock sources. At the same time, can we configure the remaining MGBE1-3 in 25G mode, and can they operate simultaneously.
Case 2 in DesignGuide seems to fit my current description well, but I haven’t found the relevant configuration method
It's `either` 4 x 10 `or` 4 x 25
https://docs.nvidia.com/jetson/archives/r39.2/DeveloperGuide/SD/Kernel/Enable25GbEthernetOnQSFP.html#
In the Jetson AGX Thor Developer Kit, the QSFP port can support both
10 Gigabit Ethernet (10GbE) and 25 Gigabit Ethernet (25GbE). The default is 10GbE.
The QSFP port can support only one configuration at a time.
To enable 25GbE, edit the flashing configuration file
jetson-agx-thor-devkit.conf and set ODMDATA as follows:
according to Table 7-21 in the manual, Case 1 conforms to the description of “4x10 Or 4x25”. It is evident that the newly added Case 2 supports the mixed use of, for example, mgbe0 as a 10g mode and mgbe1 as a 25g mode
Now that I look at Table 7-21, that does contradict the Enable25GbEthernetOnQSFP
I was going to say the following but maybe Jetpack 7.2 changed things: "In the same pdf, I think, this comes closest to what you intend.
7.2.2 Ethernet via PCIe
The Jetson Thor provides an Ethernet interface to support 5 Gigabit Ethernet functionality via PCIe Network Interface Controller (NIC). As shown in Figure 8-1 and Figure 8-2, the Ethernet PHY, magnetics, and RJ45 connector are not included on the module and must be implemented externally to the module.
The hardware supports Use Case 2 in Table 7-21 MGBE Reference Clock Connection but there currently is no software configuration available to support that.
Which version will support case 2 feature?
There is no committed release schedule or confirmed software version for supporting case 2 at this time.
