On the basis of example 02_video_dec_cuda, I changed the read-in H264 file to UDP data stream. I found that the program will read several frames of data before decoding, and after a period of time, it will need to read several frames of data before decoding. This causes the video screen to jam. What’s the reason? What I want to do is read a frame and decode a frame instead of reading several frames before decoding
We have the option disable-dpb in 00_video_decode
. Please apply it and try again.
Hi. Is 00_video_decode example decoded by CPU?
hi,Do you mean the “blocking mode” option?
about 00_video_dec.I tried mode 0 is too laggy. I use potplayer to play very smoothly, which shows that my RTP stream is OK. I don’t know what the problem is.
Please check this option:
else if (!strcmp(arg, "--disable-dpb"))
ctx->disable_dpb = true;
Thank you very much. I tried it today, and the delay really decreased. But it still has a delay of 200ms. Is there any way to accelerate it?
I feel that the algorithm has set up an input buffer. When several frames are read, the decoding starts. My problem is how to make the algorithm read a frame of data and decode a frame of data.
Since h264 streams are compressed by referring to nearby frames. For the stream like IDR, P, P, P, P, ...
, decoder always need to keep one frame for decoding next frame. There is one-frame delay in this kind of streams.
