About using PCM3010 with jetson NANO
I am not sure about your question here. Could you elaborate?
Expected to have been shared on how to resolve the issue in the Forum through Wayne,
We will contact you to check again.
You know the history well, so let me tell you the concluding part,
You need to change the GPIO settings of Pinmux @700008d4 and @6000d000 at the same time.
As I changed only @700008d4, it was an issue that the value of @6000d000 was overwrite.
Therefore, pj4,5,6,7 should be used as SFIO,
Tegra_gpio’s CNF should show 0, not f0(11110000) for that pin.
The dtb file containing the contents has already been shared,
This case will be updated in pinmmux_config_template and official documentation.
I was given the same guide as above,
I checked the jetson download center
There are no updates to the documentation for nano pinmux.
Thank you.
Aren’t you asking the issue on NX? Then what is the problem with nano document?
Sorry,
I was wrong.
I’ll try the documentation and ask again if it doesn’t work.
Thank you.
File a new topic on NX forum if you have further question on NX.
not xavier nx,
Has the documentation for nano been updated?
Thank you.
What is the exact platform here?
In this case, it was jetson nano.
I will open a new question in the nx forum.
We consider there is no need to update document. This is just our mistake not modifying pinmux @700008d4 and @6000d000 at the same time.
Okay.
Thank you.
The real story in this long thread are:
  1. In the middle of our discussion on this topic, you already not followed any document. You just directly use the dtb shared by either jonathanh or me.
  2. Thus, after (1), there is no need to change anything in doc because you were not following the document at all. And it was our mistake that forgot to tell you that you also need to modify the gpio device tree.
