About version of L4T for jetson-nano-devkit.conf
① Please tell me what L4T version is included in jetson-nano-devkit.conf
It seems that the paths of the libraries are somewhat different from the latest version.
② Should I use jetson-nano-devkit.conf when flashing the devkit module (sdcard) into a flash script?
If I can use something else, what should I choose?
Thank you.
hello neuezeal,
that jetson-nano-devkit.conf is board configuration files to flash the board, which include chip-id, emmc config, bct files, root file system size, all necessary binaries…etc.
you may download different L4T release versions via SDKManager, please also check JetPack Archive to understand the released versions of JetPack and L4T.
while you’d download the image via SDKManager, it will also save the release image locally to your host machine with JetPack version,
for example, ~/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra$
you may enable flash script to re-flash the board.
since Nano platform has emmc and sdcard versions, there’re different board configuration files you should used to flash Nano device.
