but
It says “DATE: Fri
Jun 26 04:38:25 UTC 2020”
As seen in the Quick Start Guide
jetson6 flashed with the following command.
What is different?
Could you please let me know what was updated in July?
① Has anything changed in jetson_multimedia_api?
② I am creating a library based on jetson_multimedia_api.
③ Is there a quick and easy way to track changes to jetson_multimedia_api?
Thank you.
The date marked is independent. One is the date of software system image, and the other is the date of document update. We now don’t have the release notes for jetson_multimedia_api and would need your help to check the deviation between each release. For upgrading to a new version, please make sure you upgrade the header files in
/usr/src/jetson_multimedia_api/include/
and common codes in
/usr/src/jetson_multimedia_api/samples/common/
