In nvEncodeApi.h
typedef enum _NV_ENC_BUFFER_FORMAT
NV_ENC_BUFFER_FORMAT_UNDEFINED = 0x00000000, /**< Undefined buffer format */
NV_ENC_BUFFER_FORMAT_NV12 = 0x00000001, /**< Semi-Planar YUV [Y plane followed by interleaved UV plane] */
NV_ENC_BUFFER_FORMAT_YV12 = 0x00000010, /**< Planar YUV [Y plane followed by V and U planes] */
NV_ENC_BUFFER_FORMAT_IYUV = 0x00000100, /**< Planar YUV [Y plane followed by U and V planes] */
NV_ENC_BUFFER_FORMAT_YUV444 = 0x00001000, /**< Planar YUV [Y plane followed by U and V planes] */
NV_ENC_BUFFER_FORMAT_YUV420_10BIT = 0x00010000, /**< 10 bit Semi-Planar YUV [Y plane followed by interleaved UV plane]. Each pixel of size 2 bytes. Most Significant 10 bits contain pixel data. */
NV_ENC_BUFFER_FORMAT_YUV444_10BIT = 0x00100000, /**< 10 bit Planar YUV444 [Y plane followed by U and V planes]. Each pixel of size 2 bytes. Most Significant 10 bits contain pixel data. */
NV_ENC_BUFFER_FORMAT_ARGB = 0x01000000, /**< 8 bit Packed A8R8G8B8. This is a word-ordered format
where a pixel is represented by a 32-bit word with B
in the lowest 8 bits, G in the next 8 bits, R in the
8 bits after that and A in the highest 8 bits. */
NV_ENC_BUFFER_FORMAT_ARGB10 = 0x02000000, /**< 10 bit Packed A2R10G10B10. This is a word-ordered format
in the lowest 10 bits, G in the next 10 bits, R in the
10 bits after that and A in the highest 2 bits. */
NV_ENC_BUFFER_FORMAT_AYUV = 0x04000000, /**< 8 bit Packed A8Y8U8V8. This is a word-ordered format
where a pixel is represented by a 32-bit word with V
in the lowest 8 bits, U in the next 8 bits, Y in the
NV_ENC_BUFFER_FORMAT_ABGR = 0x10000000, /**< 8 bit Packed A8B8G8R8. This is a word-ordered format
where a pixel is represented by a 32-bit word with R
in the lowest 8 bits, G in the next 8 bits, B in the
NV_ENC_BUFFER_FORMAT_ABGR10 = 0x20000000, /**< 10 bit Packed A2B10G10R10. This is a word-ordered format
in the lowest 10 bits, G in the next 10 bits, B in the
} NV_ENC_BUFFER_FORMAT;
So YUV i420 format is not in the list,how to suport i420 encode?
