About xavier EQOS MAC to MAC
eth0 in DHCP mode.
i’ve changed eqos from built-in to module in kernel source, after insert module eqos:
sudo modprobe eqos
$ dmesg
[5月23 09:36] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b e5 79 bb
[ +0.001103] libphy: dwc_phy: probed
[ +0.000029] mdio_bus dwc_phy-1:00: mdio_device_register
[ +0.000159] mdio_bus dwc_phy-1: registered mdio device switch0 at address 0
[ +0.089679] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ +0.011674] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ +1.014820] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control off
[ +0.000104] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
$ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::4c2b:543d:93b4:2b9b prefixlen 64 scopeid 0x20
ether 00:04:4b:e5:79:bb txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 21 bytes 3776 (3.7 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 40
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1 (Local Loopback)
RX packets 799 bytes 51051 (51.0 KB)
TX packets 799 bytes 51051 (51.0 KB)
rndis0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether c6:c0:ed:01:43:c5 txqueuelen 1000 (Ethernet)
TX packets 0 bytes 0 (0.0 B)
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether c6:c0:ed:01:43:c7 txqueuelen 1000 (Ethernet)
$ ethtool -S eth0
NIC statistics:
mmc_tx_octetcount_gb: 7548
mmc_tx_framecount_gb: 42
mmc_tx_broadcastframe_g: 9
mmc_tx_multicastframe_g: 33
mmc_tx_64_octets_gb: 0
mmc_tx_65_to_127_octets_gb: 19
mmc_tx_128_to_255_octets_gb: 14
mmc_tx_256_to_511_octets_gb: 9
mmc_tx_512_to_1023_octets_gb: 0
mmc_tx_1024_to_max_octets_gb: 0
mmc_tx_unicast_gb: 0
mmc_tx_multicast_gb: 33
mmc_tx_broadcast_gb: 9
mmc_tx_underflow_error: 0
mmc_tx_singlecol_g: 0
mmc_tx_multicol_g: 0
mmc_tx_deferred: 0
mmc_tx_latecol: 0
mmc_tx_exesscol: 0
mmc_tx_carrier_error: 0
mmc_tx_octetcount_g: 7548
mmc_tx_framecount_g: 42
mmc_tx_excessdef: 0
mmc_tx_pause_frame: 0
mmc_tx_vlan_frame_g: 0
mmc_rx_framecount_gb: 0
mmc_rx_octetcount_gb: 0
mmc_rx_octetcount_g: 0
mmc_rx_broadcastframe_g: 0
mmc_rx_multicastframe_g: 0
mmc_rx_crc_errror: 0
mmc_rx_align_error: 0
mmc_rx_run_error: 0
mmc_rx_jabber_error: 0
mmc_rx_undersize_g: 0
mmc_rx_oversize_g: 0
mmc_rx_64_octets_gb: 0
mmc_rx_65_to_127_octets_gb: 0
mmc_rx_128_to_255_octets_gb: 0
mmc_rx_256_to_511_octets_gb: 0
mmc_rx_512_to_1023_octets_gb: 0
mmc_rx_1024_to_max_octets_gb: 0
mmc_rx_unicast_g: 0
mmc_rx_length_error: 0
mmc_rx_outofrangetype: 0
mmc_rx_pause_frames: 0
mmc_rx_fifo_overflow: 0
mmc_rx_vlan_frames_gb: 0
mmc_rx_watchdog_error: 0
mmc_rx_ipc_intr_mask: 1073692671
mmc_rx_ipc_intr: 0
mmc_rx_ipv4_gd: 0
mmc_rx_ipv4_hderr: 0
mmc_rx_ipv4_nopay: 0
mmc_rx_ipv4_frag: 0
mmc_rx_ipv4_udsbl: 0
mmc_rx_ipv6_gd_octets: 0
mmc_rx_ipv6_hderr_octets: 0
mmc_rx_ipv6_nopay_octets: 0
mmc_rx_udp_gd: 0
mmc_rx_udp_err: 0
mmc_rx_tcp_gd: 0
mmc_rx_tcp_err: 0
mmc_rx_icmp_gd: 0
mmc_rx_icmp_err: 0
mmc_rx_ipv4_gd_octets: 0
mmc_rx_ipv4_hderr_octets: 0
mmc_rx_ipv4_nopay_octets: 0
mmc_rx_ipv4_frag_octets: 0
mmc_rx_ipv4_udsbl_octets: 0
mmc_rx_ipv6_gd: 0
mmc_rx_ipv6_hderr: 0
mmc_rx_ipv6_nopay: 0
mmc_rx_udp_gd_octets: 0
mmc_rx_udp_err_octets: 0
mmc_rx_tcp_gd_octets: 0
mmc_rx_tcp_err_octets: 0
mmc_rx_icmp_gd_octets: 0
mmc_rx_icmp_err_octets: 0
q_re_alloc_rx_buf_failed[0]: 0
q_re_alloc_rx_buf_failed[1]: 0
q_re_alloc_rx_buf_failed[2]: 0
q_re_alloc_rx_buf_failed[3]: 0
q_re_alloc_rx_buf_failed[4]: 0
q_re_alloc_rx_buf_failed[5]: 0
q_re_alloc_rx_buf_failed[6]: 0
q_re_alloc_rx_buf_failed[7]: 0
tx_process_stopped_irq_n[0]: 0
tx_process_stopped_irq_n[1]: 0
tx_process_stopped_irq_n[2]: 0
tx_process_stopped_irq_n[3]: 0
tx_process_stopped_irq_n[4]: 0
tx_process_stopped_irq_n[5]: 0
tx_process_stopped_irq_n[6]: 0
tx_process_stopped_irq_n[7]: 0
rx_process_stopped_irq_n[0]: 0
rx_process_stopped_irq_n[1]: 0
rx_process_stopped_irq_n[2]: 0
rx_process_stopped_irq_n[3]: 0
rx_process_stopped_irq_n[4]: 0
rx_process_stopped_irq_n[5]: 0
rx_process_stopped_irq_n[6]: 0
rx_process_stopped_irq_n[7]: 0
tx_buf_unavailable_irq_n[0]: 0
tx_buf_unavailable_irq_n[1]: 0
tx_buf_unavailable_irq_n[2]: 0
tx_buf_unavailable_irq_n[3]: 0
tx_buf_unavailable_irq_n[4]: 0
tx_buf_unavailable_irq_n[5]: 0
tx_buf_unavailable_irq_n[6]: 0
tx_buf_unavailable_irq_n[7]: 0
rx_buf_unavailable_irq_n[0]: 0
rx_buf_unavailable_irq_n[1]: 0
rx_buf_unavailable_irq_n[2]: 0
rx_buf_unavailable_irq_n[3]: 0
rx_buf_unavailable_irq_n[4]: 0
rx_buf_unavailable_irq_n[5]: 0
rx_buf_unavailable_irq_n[6]: 0
rx_buf_unavailable_irq_n[7]: 0
rx_watchdog_irq_n: 0
fatal_bus_error_irq_n: 0
pmt_irq_n: 0
tx_normal_irq_n[0]: 42
tx_normal_irq_n[1]: 0
tx_normal_irq_n[2]: 0
tx_normal_irq_n[3]: 0
tx_normal_irq_n[4]: 0
tx_normal_irq_n[5]: 0
tx_normal_irq_n[6]: 0
tx_normal_irq_n[7]: 0
rx_normal_irq_n[0]: 0
rx_normal_irq_n[1]: 0
rx_normal_irq_n[2]: 0
rx_normal_irq_n[3]: 0
rx_normal_irq_n[4]: 0
rx_normal_irq_n[5]: 0
rx_normal_irq_n[6]: 0
rx_normal_irq_n[7]: 0
napi_poll_n: 0
tx_clean_n[0]: 42
tx_clean_n[1]: 0
tx_clean_n[2]: 0
tx_clean_n[3]: 0
tx_clean_n[4]: 0
tx_clean_n[5]: 0
tx_clean_n[6]: 0
tx_clean_n[7]: 0
tx_path_in_lpi_mode_irq_n: 0
tx_path_exit_lpi_mode_irq_n: 0
rx_path_in_lpi_mode_irq_n: 0
rx_path_exit_lpi_mode_irq_n: 0
tx_pkt_n: 42
rx_pkt_n: 0
tx_vlan_pkt_n: 0
rx_vlan_pkt_n: 0
tx_timestamp_captured_n: 0
rx_timestamp_captured_n: 0
tx_tso_pkt_n: 0
q_tx_pkt_n[0]: 42
q_tx_pkt_n[1]: 0
q_tx_pkt_n[2]: 0
q_tx_pkt_n[3]: 0
q_tx_pkt_n[4]: 0
q_tx_pkt_n[5]: 0
q_tx_pkt_n[6]: 0
q_tx_pkt_n[7]: 0
q_rx_pkt_n[0]: 0
q_rx_pkt_n[1]: 0
q_rx_pkt_n[2]: 0
q_rx_pkt_n[3]: 0
q_rx_pkt_n[4]: 0
q_rx_pkt_n[5]: 0
q_rx_pkt_n[6]: 0
q_rx_pkt_n[7]: 0
link_disconnect_count: 0
link_connect_count: 1
