Hi NVIDIA NIM team,
My account info
API Key suffix:
KnJabS -
Registered email:
1149393438@qq.com
About me (academic identity)
I am a Ph.D. student at a university, focusing on computational linguistics and early detection of neurodegenerative diseases. My ORCID profile is available here for verification:
https://orcid.org/0009-0003-7647-6419
Research background (strictly non‑commercial, academic)
My project is titled “Early detection of Alzheimer’s disease using spontaneous speech analysis”. We collect speech samples from elderly participants (picture description, free recall tasks) and aim to build classification models by analysing both linguistic features (semantic fluency, syntactic complexity, etc.) and acoustic features (speech rate, pause patterns, prosody).
My Agent pipeline – why I need a higher RPM
I have built an AI Agent that automates the entire analysis pipeline. The Agent makes sequential API calls for each speech sample, using the following components (all available via NVIDIA NIM free tier):
Speech foundation model – extracts acoustic features directly from raw audio (e.g., pitch variation, energy fluctuation, speaking rate) as early markers of cognitive decline.
ASR model – transcribes the audio into text for downstream analysis.
RAG (Retrieval-Augmented Generation) – uses an embedding model and a rerank model to retrieve relevant knowledge from external corpora, ensuring accurate linguistic feature extraction.
Text LLM (Kimi 2.6) – acts as the Agent’s reasoning and decision‑making core, coordinating the entire pipeline, extracting linguistic features, and producing structured output.
Why the 40 RPM limit is insufficient
Each single speech sample requires 6–8 sequential API calls (speech feature extraction → ASR → RAG retrieval → LLM reasoning → final output).
Each participant contributes multiple samples (e.g., different speech tasks).
A typical research batch includes 50–100 participants, each with 3–5 samples on average.
This means a batch can easily involve hundreds to thousands of total API calls. Even when processed serially with careful throttling, this workload frequently exceeds the current 40 RPM limit, causing 429 errors and long exponential backoff delays, which severely slows down my research.
Request
Could you please increase my rate limit from 40 RPM to 200 RPM? This would allow my academic pipeline to run without constant interruptions. I confirm that this is strictly for non‑profit research (dementia early screening) and will not be used for production or commercial purposes.
Thank you very much for supporting academic research.
Best regards,
Xiao Wei
