Platform: Windows 10 home
Device: GTX 1060 (in an Alienware laptop)
Compiler: PGI Community Edition 18.10 and 19.4
Situation: The code can be compiled well by 18.10 and 19.4. The 18.10 exe can run correctly, however, the 19.4 compiled exe can not run.
Code:
# include <stdlib.h>
# include <stdio.h>
int main()
int i, j, M;
float **a;
M = 4;
a = (float**)malloc(sizeof(float*) * M);
#pragma acc enter data create(a[0:M][0:1])
for (i = 0; i < M; i++)
if (i > 0)
a[i] = (float*)malloc(i * sizeof(float));
#pragma acc enter data create(a[i:1][0:i])
// Initial value
if (i > 0)
for (j = 0; j < i; j++)
a[i][j] = 1000.0f;
#pragma acc update device(a[i:1][0:i])
#pragma acc parallel loop present(a)
if (i > 0)
a[i][j] += i * 10 + j;
if (i > 0)
#pragma acc update host(a[i:1][0:i])
printf("%f ", a[i][j]);
printf("\n");
else
printf("NULL\n");
#pragma acc exit data delete(a[i:1])
free(a[i]);
#pragma acc exit data delete(a)
free(a);
return 0;
Compile command:
pgcc -acc -Minfo a.c -o a.exe
Compile response:
main:
12, Generating enter data create(a[:M][:1])
18, Generating enter data create(a[i][:i])
27, Memory set idiom, loop replaced by call to __c_mset4
33, Generating update device(a[i][:i])
35, Generating present(a[:][:])
Generating Tesla code
36, #pragma acc loop gang /* blockIdx.x */
40, #pragma acc loop vector(128) /* threadIdx.x */
40, Loop is parallelizable
52, Generating update self(a[i][:i])
66, Generating exit data delete(a[:1][i])
69, Generating exit data delete(a[:1][:1])
Execution error message:
hostptr=00000000005EDEE0,stride=1,-1,size=1x1,extent=-1x-1,eltsize=4,name=a,flags=0x200=present,async=-1,threadid=1
Present table dump for device[1]: NVIDIA Tesla GPU 0, compute capability 6.1, threadid=1
host:0000000000000000 device:0000000000000000 size:0 presentcount:0+1 line:18 name:a
host:00000000005EDEE0 device:0000000B03C00000 size:32 presentcount:2+1 line:12 name:a
host:000000000D118CB0 device:0000000B03C00400 size:8 presentcount:0+1 line:18 name:a
host:000000000D119070 device:0000000B03C00600 size:12 presentcount:0+1 line:18 name:a
host:000000000D1190C0 device:0000000B03C00200 size:4 presentcount:0+1 line:18 name:a
allocated block device:0000000B03C00000 size:512 thread:1
allocated block device:0000000B03C00200 size:512 thread:1
allocated block device:0000000B03C00400 size:512 thread:1
allocated block device:0000000B03C00600 size:512 thread:1
FATAL ERROR: data in PRESENT clause was not found on device 1: name=a host:00000000005EDEE0
file:E:\SourceCode\OpenaccCExamples\acc_2darray_jagged\acc_2darray_jagged.c main line:35
Please help me. Thank you very much!
