ACC routine needed in Do Concurrent and Pure Functions
I have been experimenting with the new ability to have pure functions in DO CONCURRENT loops. In my testing, I have found that it is necessary to have “!$acc routine (func) seq” in my pure functions for the code to compile. Does this mean “!$acc routine” is needed for a pure function in a DO CONCURRENT loop? I have included a code sample. The first code compiles correctly and runs, but once the “!$acc routine” is deleted (second code) the code will not compile. Both codes are compiled with -stdpar=gpu.
      module addTwo_interface
!$acc routine(addTwo) seq
      interface
        pure function addTwo (num)
          implicit none
          real, intent(in) :: num
          real, intent(out) :: addTwo
        end function addTwo
      end interface
      end module
c
c-----------------------------------------------------------------------
c
      program TEST
      implicit none
      real :: numbers(5,5)
      integer :: i,j
      integer, dimension(:,:), allocatable :: temp
      allocate(temp(5,5))
c
      call set_data(numbers)
c
      do i=1,5
        print*, numbers(i,1)
      enddo
      end program
c
c
      subroutine set_data(numbers)
        use addTwo_interface
        implicit none
        integer :: i,j
        do concurrent (i=1:5,j=1:5)
           numbers(i,j) = addTwo(1.0)
        enddo
      end subroutine
c
c
      pure function addTwo(num)
        implicit none
c
        addTwo = num+2.0
c
      end function
Second code :
      interface
          implicit none
        end function addTwo
      end interface
      end module
c
c
      program TEST
      implicit none
      integer :: i,j
      allocate(temp(5,5))
c
c
      do i=1,5
      enddo
      end program
c
c
        implicit none
        integer :: i,j
        enddo
      end subroutine
c
c
        implicit none
c
        addTwo = num+2.0
c
      end function
  • Miko
Hi Miko,
A pure function just guarantees that it has no side effects but as far as calling, it’s no different than any other function or routine. Given we don’t yet support auto generation of device subroutines with DO CONNCURRENT, it does mean that all functions need to use the OpenACC routine directive in order to create the device callable version.
However, pure functions are much easier for the compiler to inline, so one work around would be to add the “-Minline” flag during compilation. If in your full application the function is in a separate file, then you’d want to do a two pass compilation. First compile with “-Mextract=lib:” to create the inline library, and then a second compile with “-Minline=lib:” to have the compiler use this info to inline the function.
-Mat
