• Hardware Platform (Jetson / GPU): RTX 4090 • DeepStream Version: 9.0 • JetPack Version (valid for Jetson only): N/A • TensorRT Version: 11.0.0.114-1+cuda13.2 • NVIDIA GPU Driver Version (valid for GPU only): 595.71.05 • Issue Type( questions, new requirements, bugs): bug • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
**• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
I have 2 videos of 3 people walking around a room, which I used on AutoMagicCalib to get the calibration. AMC did not work but vggt got a good estimate for my cameras position.**
I recorded the videos and used them for calibration.
When I open the videos on VLC, they run at normal speed.
I used a slightly modified ./scripts/test_4cam_ds.sh script, but with the path for my 2 videos and the calibration data.
One of them gets highly accelerated when I run the script.
Why is this happening?
Here I am running MV3DT with both videos.
Both videos playback is faster then normal speed, but one of them is even faster and it ends before the other, which interrupts the execution at the end.
BEV shows nothing.
As you changed the input video from 4 to 2, suppose all the configure file batch size should change from 4 to 2. Can you share all the configure file(deepstream config/PGIE config/tracker config)
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
