Hi Mat,
program main
use accel_lib
integer :: n ! size of the vector
real,dimension(:),allocatable :: a ! the vector
real,dimension(:),allocatable :: r ! the results
real,dimension(:),allocatable :: e ! expected results
integer :: i
integer :: c0, c1, c2, c3, cgpu, chost
character(10) :: arg1
if( iargc() .gt. 0 )then
call getarg( 1, arg1 )
read(arg1,’(i10)’) n
else
n = 100000
endif
if( n .le. 0 ) n = 100000
allocate(a(n))
allocate(r(n))
allocate(e(n))
do i = 1,n
a(i) = i*2.0
enddo
call acc_init( acc_device_nvidia )
call system_clock( count=c1 )
!$acc region
do i = 1,n
r(i) = sin(a(i)) ** 2 + cos(a(i)) ** 2
enddo
!$acc end region
call system_clock( count=c2 )
cgpu = c2 - c1
do i = 1,n
e(i) = sin(a(i)) ** 2 + cos(a(i)) ** 2
enddo
call system_clock( count=c3 )
chost = c3 - c2
! check the results
do i = 1,n
if( abs(r(i) - e(i)) .gt. 0.000001 )then
print *, i, r(i), e(i)
endif
enddo
print *, n, ’ iterations completed’
print *, cgpu, ’ microseconds on GPU’
print *, chost, ’ microseconds on host’
end program
I run this program ,the output:
100000 iterations completed
0 microseconds on GPU
0 microseconds on host
Why?
