Acces object meta using object id
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5.1
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 470
• Issue Type( questions, new requirements, bugs) how to access the stored meta data using any object id
i have the following code, there i have stored all the persons object meta into a list, and in another object loop i want to access the meta data of stored persons. is there any unique id assigning to every detected objects?
#!/usr/bin/env python3
# Copyright (c) 2020, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
import sys
sys.path.append('../')
import platform
import configparser
import gi
gi.require_version('Gst', '1.0')
from gi.repository import GObject, Gst
from common.is_aarch_64 import is_aarch64
from common.bus_call import bus_call
import pyds
import torch
import torchvision.ops.boxes as bops
import cv2
import numpy as np
PGIE_CLASS_ID_TOOTHBRUSH = 79
PGIE_CLASS_ID_HAIR_DRYER = 78
PGIE_CLASS_ID_TEDDY_BEAR = 77
PGIE_CLASS_ID_SCISSORS = 76
PGIE_CLASS_ID_VASE = 75
PGIE_CLASS_ID_CLOCK = 74
PGIE_CLASS_ID_BOOK = 73
PGIE_CLASS_ID_REFRIGERATOR = 72
PGIE_CLASS_ID_SINK = 71
PGIE_CLASS_ID_TOASTER = 70
PGIE_CLASS_ID_OVEN = 69
PGIE_CLASS_ID_MICROWAVE = 68
PGIE_CLASS_ID_CELL_PHONE = 67
PGIE_CLASS_ID_KEYBOARD = 66
PGIE_CLASS_ID_REMOTE = 65
PGIE_CLASS_ID_MOUSE = 64
PGIE_CLASS_ID_LAPTOP = 63
PGIE_CLASS_ID_TVMONITOR = 62
PGIE_CLASS_ID_TOILET = 61
PGIE_CLASS_ID_DININGTABLE= 60
PGIE_CLASS_ID_BED = 59
PGIE_CLASS_ID_POTTEDPLANT = 58
PGIE_CLASS_ID_SOFA = 57
PGIE_CLASS_ID_CHAIR = 56
PGIE_CLASS_ID_CAKE = 55
PGIE_CLASS_ID_DONUT = 54
PGIE_CLASS_ID_PIZZA = 53
PGIE_CLASS_ID_HOT_DOG = 52
PGIE_CLASS_ID_CARROT = 51
PGIE_CLASS_ID_BROCCOLI = 50
PGIE_CLASS_ID_ORANGE = 49
PGIE_CLASS_ID_SANDWICH = 48
PGIE_CLASS_ID_APPLE = 47
PGIE_CLASS_ID_BANANA = 46
PGIE_CLASS_ID_BOWL = 45
PGIE_CLASS_ID_SPOON = 44
PGIE_CLASS_ID_KNIFE = 43
PGIE_CLASS_ID_FORK = 42
PGIE_CLASS_ID_CUP = 41
PGIE_CLASS_ID_WINE_GLASS = 40
PGIE_CLASS_ID_BOTTLE = 39
PGIE_CLASS_ID_TENNIS_RACKET = 38
PGIE_CLASS_ID_SURFBOARD = 37
PGIE_CLASS_ID_SKATEBOARD = 36
PGIE_CLASS_ID_BASEBALL_GLOVE = 35
PGIE_CLASS_ID_BASEBALL_BAT = 34
PGIE_CLASS_ID_KITE = 33
PGIE_CLASS_ID_SPORTS_BALL = 32
PGIE_CLASS_ID_SNOWBOARD = 31
PGIE_CLASS_ID_SKIS = 30
PGIE_CLASS_ID_FRISBEE = 29
PGIE_CLASS_ID_SUITCASE = 28
PGIE_CLASS_ID_TIE = 27
PGIE_CLASS_ID_HANDBAG = 26
PGIE_CLASS_ID_UMBRELLA = 25
PGIE_CLASS_ID_BACKPACK = 24
PGIE_CLASS_ID_GIRAFFE = 23
PGIE_CLASS_ID_ZEBRA = 22
PGIE_CLASS_ID_BEAR = 21
PGIE_CLASS_ID_ELEPHANT = 20
PGIE_CLASS_ID_COW = 19
PGIE_CLASS_ID_SHEEP = 18
PGIE_CLASS_ID_HORSE = 17
PGIE_CLASS_ID_DOG = 16
PGIE_CLASS_ID_CAT = 15
PGIE_CLASS_ID_BIRD = 14
PGIE_CLASS_ID_BENCH = 13
PGIE_CLASS_ID_PARKING_METER = 12
PGIE_CLASS_ID_STOP_SIGN = 11
PGIE_CLASS_ID_FIRE_HYDRANT = 10
PGIE_CLASS_ID_TRAFFIC_LIGHT = 9
PGIE_CLASS_ID_BOAT = 8
PGIE_CLASS_ID_TRUCK = 7
PGIE_CLASS_ID_TRAIN = 6
PGIE_CLASS_ID_BUS = 5
PGIE_CLASS_ID_AEROPLANE = 4
PGIE_CLASS_ID_MOTORBIKE = 3
PGIE_CLASS_ID_VEHICLE = 2
PGIE_CLASS_ID_BICYCLE = 1
PGIE_CLASS_ID_PERSON = 0
past_tracking_meta=[0]
def calculate_iou(persons, bag): # box2-> baggages
    ious = {'output': {'bbox': [], 'box1':[], 'box2': []}}
    for p_box in persons:
        ious['output']['bbox'].append(bops.box_iou(p_box[:, 1:], bag[:, 1:]).tolist())
        ious['output']['box1'].append(p_box)
        ious['output']['box2'].append(bag)
    outputs = {"bbox":[], "box1": [], "box2": []}
    try:
        idx_list = np.nonzero(ious['output']['bbox'])
        for idx in idx_list[0]:
            outputs["bbox"].append(ious['output']['bbox'][idx])
            outputs["box1"].append(ious['output']['box1'][idx])
            outputs["box2"].append(ious['output']['box2'][idx])
        return outputs["bbox"], outputs["box1"], outputs["box2"]
    except Exception as e:
        print(e)
        outputs = None, None, None
        return outputs
def torchTolist(box): #, conf, cls):
    t_box = box[0][0].tolist()
    # t_box.append(conf.tolist())
    # t_box.append(cls.tolist())
    return t_box
def pgie_sink_pad_buffer_probe(pad, info, u_data):
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    # Retrieve batch metadata from the gst_buffer
    # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
    # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.glist_get_nvds_frame_meta()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
            #frame_meta = pyds.glist_get_nvds_frame_meta(l_frame.data)
        except StopIteration:
            break
        frame_number=frame_meta.frame_num
        num_rects = frame_meta.num_obj_meta
        l_obj=frame_meta.obj_meta_list
        p_obj=frame_meta.obj_meta_list
        persons = []
        while p_obj is not None:
            try:
                # Casting l_obj.data to pyds.NvDsObjectMeta
                #obj_meta=pyds.glist_get_nvds_object_meta(l_obj.data)
                obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
                break
            bbox={'obj_id':obj_meta.object_id,
                  'xmin':obj_meta.rect_params.left,
                  'ymin':obj_meta.rect_params.left+obj_meta.rect_params.width,
                  'xmax':obj_meta.rect_params.top+obj_meta.rect_params.height,
                  'ymax':obj_meta.rect_params.top}
            persons.append(torch.tensor([[bbox['obj_id'], bbox['xmin'], bbox['ymin'],
                                          bbox['xmax'], bbox['ymax']]]))
            try:
                p_obj=p_obj.next
                break
        while l_obj is not None:
            try:
                break
            # n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
            if obj_meta.class_id in [24, 26, 28]:
                baggage= torch.tensor([[bbox['obj_id'], bbox['xmin'], bbox['ymin'], bbox['xmax'], bbox['ymax']]])
                ious, box1, box2 = calculate_iou(persons, baggage)
                if ious and len(ious)==1:
                    # experimental bufffer modification
                    # here we need to pass only few objects to buffer
                    obj_meta.class_id = 220
#                     bbox = torchTolist(box2)
#                     pbox = torchTolist(box1)
#                     color = (0, 0, 255, 0)
#                     n_frame = draw_bounding_boxes(n_frame, bbox, str(obj_meta.obj_label), 0, color)
#                     n_frame = draw_bounding_boxes(n_frame, pbox, 'person', 0, color)
                if ious and len(ious)>1:
#                     pass
                    # call pose estimation
                    # all person keypoints
#                     idx= np.array(ious).argmax()
#                     bbox = box2[idx][0].tolist()
#                     pbox = box1[idx][0].tolist()
#                     n_frame = draw_bounding_boxes(n_frame, bbox, str(obj_meta.obj_label), obj_meta.confidence, color)
#                     n_frame = draw_bounding_boxes(n_frame, pbox, 'person', obj_meta.confidence, color)
                else:
                    # color = (0, 0, 0, 255)
                    # bbox = torchTolist([baggage])
                    # n_frame = draw_bounding_boxes(n_frame, bbox, str(obj_meta.obj_label), 100, color)
            try:
                l_obj=l_obj.next
                break
        try:
            l_frame=l_frame.next
            break
    return Gst.PadProbeReturn.OK
def osd_sink_pad_buffer_probe(pad,info,u_data):
    frame_number=0
    #Intiallizing object counter with 0.
    obj_counter = {
        PGIE_CLASS_ID_TOOTHBRUSH:0,
        PGIE_CLASS_ID_HAIR_DRYER:0,
        PGIE_CLASS_ID_TEDDY_BEAR:0,
        PGIE_CLASS_ID_SCISSORS:0,
        PGIE_CLASS_ID_VASE:0,
        PGIE_CLASS_ID_CLOCK:0,
        PGIE_CLASS_ID_BOOK:0,
        PGIE_CLASS_ID_REFRIGERATOR:0,
        PGIE_CLASS_ID_SINK:0,
        PGIE_CLASS_ID_TOASTER:0,
        PGIE_CLASS_ID_OVEN:0,
        PGIE_CLASS_ID_MICROWAVE:0,
        PGIE_CLASS_ID_CELL_PHONE:0,
        PGIE_CLASS_ID_KEYBOARD:0,
        PGIE_CLASS_ID_REMOTE:0,
        PGIE_CLASS_ID_MOUSE:0,
        PGIE_CLASS_ID_LAPTOP:0,
        PGIE_CLASS_ID_TVMONITOR:0,
        PGIE_CLASS_ID_TOILET:0,
        PGIE_CLASS_ID_DININGTABLE:0,
        PGIE_CLASS_ID_BED:0,
        PGIE_CLASS_ID_POTTEDPLANT:0,
        PGIE_CLASS_ID_SOFA:0,
        PGIE_CLASS_ID_CHAIR:0,
        PGIE_CLASS_ID_CAKE:0,
        PGIE_CLASS_ID_DONUT:0,
        PGIE_CLASS_ID_PIZZA:0,
        PGIE_CLASS_ID_HOT_DOG:0,
        PGIE_CLASS_ID_CARROT:0,
        PGIE_CLASS_ID_BROCCOLI:0,
        PGIE_CLASS_ID_ORANGE:0,
        PGIE_CLASS_ID_SANDWICH:0,
        PGIE_CLASS_ID_APPLE:0,
        PGIE_CLASS_ID_BANANA:0,
        PGIE_CLASS_ID_BOWL:0,
        PGIE_CLASS_ID_SPOON:0,
        PGIE_CLASS_ID_KNIFE:0,
        PGIE_CLASS_ID_FORK:0,
        PGIE_CLASS_ID_CUP:0,
        PGIE_CLASS_ID_WINE_GLASS:0,
        PGIE_CLASS_ID_BOTTLE:0,
        PGIE_CLASS_ID_TENNIS_RACKET:0,
        PGIE_CLASS_ID_SURFBOARD:0,
        PGIE_CLASS_ID_SKATEBOARD:0,
        PGIE_CLASS_ID_BASEBALL_GLOVE:0,
        PGIE_CLASS_ID_BASEBALL_BAT:0,
        PGIE_CLASS_ID_KITE:0,
        PGIE_CLASS_ID_SPORTS_BALL:0,
        PGIE_CLASS_ID_SNOWBOARD:0,
        PGIE_CLASS_ID_SKIS:0,
        PGIE_CLASS_ID_FRISBEE:0,
        PGIE_CLASS_ID_SUITCASE:0,
        PGIE_CLASS_ID_TIE:0,
        PGIE_CLASS_ID_HANDBAG:0,
        PGIE_CLASS_ID_UMBRELLA:0,
        PGIE_CLASS_ID_BACKPACK:0,
        PGIE_CLASS_ID_GIRAFFE:0,
        PGIE_CLASS_ID_ZEBRA:0,
        PGIE_CLASS_ID_BEAR:0,
        PGIE_CLASS_ID_ELEPHANT:0,
        PGIE_CLASS_ID_COW:0,
        PGIE_CLASS_ID_SHEEP:0,
        PGIE_CLASS_ID_HORSE:0,
        PGIE_CLASS_ID_DOG:0,
        PGIE_CLASS_ID_CAT:0,
        PGIE_CLASS_ID_BIRD:0,
        PGIE_CLASS_ID_BENCH:0,
        PGIE_CLASS_ID_PARKING_METER:0,
        PGIE_CLASS_ID_STOP_SIGN:0,
        PGIE_CLASS_ID_FIRE_HYDRANT:0,
        PGIE_CLASS_ID_TRAFFIC_LIGHT:0,
        PGIE_CLASS_ID_BOAT:0,
        PGIE_CLASS_ID_TRUCK:0,
        PGIE_CLASS_ID_TRAIN:0,
        PGIE_CLASS_ID_BUS:0,
        PGIE_CLASS_ID_AEROPLANE:0,
        PGIE_CLASS_ID_MOTORBIKE:0,
        PGIE_CLASS_ID_VEHICLE:0,
        PGIE_CLASS_ID_BICYCLE:0,
        PGIE_CLASS_ID_PERSON:0
    num_rects=0
    if not gst_buffer:
        return
        try:
            # The casting is done by pyds.NvDsFrameMeta.cast()
            # it alone.
            break
            try:
                break
            if obj_meta.class_id == 220:
                continue
            else:
                obj_meta.rect_params.top = 0.
                obj_meta.rect_params.left = 0.
                obj_meta.rect_params.width = 0.
                obj_meta.rect_params.height = 0.
                obj_meta.obj_label = ''
            try:
                l_obj=l_obj.next
                break
#         # convert python array into numpy array format in the copy mode.
#         frame_copy = np.array(n_frame, copy=True, order='C')
#         # convert the array into cv2 default color format
#         frame_copy = cv2.cvtColor(frame_copy, cv2.COLOR_RGBA2BGRA)
#         # send_json_api()
#         cv2.imwrite(f'imgs/frame{frame_number}.png', frame_copy)
        # Acquiring a display meta object. The memory ownership remains in
        # the C code so downstream plugins can still access it. Otherwise
        # the garbage collector will claim it when this probe function exits.
        display_meta=pyds.nvds_acquire_display_meta_from_pool(batch_meta)
        display_meta.num_labels = 1
        py_nvosd_text_params = display_meta.text_params[0]
        # Setting display text to be shown on screen
        # Note that the pyds module allocates a buffer for the string, and the
        # memory will not be claimed by the garbage collector.
        # Reading the display_text field here will return the C address of the
        # allocated string. Use pyds.get_string() to get the string content.
        py_nvosd_text_params.display_text = "Frame Number={} Number of Objects={} Person_count={}".format(frame_number, num_rects, obj_counter[PGIE_CLASS_ID_PERSON])
        # Now set the offsets where the string should appear
        py_nvosd_text_params.x_offset = 10
        py_nvosd_text_params.y_offset = 12
        # Font , font-color and font-size
        py_nvosd_text_params.font_params.font_name = "Serif"
        py_nvosd_text_params.font_params.font_size = 10
        # set(red, green, blue, alpha); set to White
        py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
        # Text background color
        py_nvosd_text_params.set_bg_clr = 1
        # set(red, green, blue, alpha); set to Black
        py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
        # Using pyds.get_string() to get display_text as string
        print(pyds.get_string(py_nvosd_text_params.display_text))
        pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
        try:
            break
    #past traking meta data
    if(past_tracking_meta[0]==1):
        l_user=batch_meta.batch_user_meta_list
        while l_user is not None:
            try:
                # Note that l_user.data needs a cast to pyds.NvDsUserMeta
                # The casting is done by pyds.NvDsUserMeta.cast()
                # it alone
                user_meta=pyds.NvDsUserMeta.cast(l_user.data)
                break
            if(user_meta and user_meta.base_meta.meta_type==pyds.NvDsMetaType.NVDS_TRACKER_PAST_FRAME_META):
                try:
                    # Note that user_meta.user_meta_data needs a cast to pyds.NvDsPastFrameObjBatch
                    # The casting is done by pyds.NvDsPastFrameObjBatch.cast()
                    # it alone
                    pPastFrameObjBatch = pyds.NvDsPastFrameObjBatch.cast(user_meta.user_meta_data)
                    break
                for trackobj in pyds.NvDsPastFrameObjBatch.list(pPastFrameObjBatch):
                    print("streamId=",trackobj.streamID)
                    print("surfaceStreamID=",trackobj.surfaceStreamID)
                    for pastframeobj in pyds.NvDsPastFrameObjStream.list(trackobj):
                        print("numobj=",pastframeobj.numObj)
                        print("uniqueId=",pastframeobj.uniqueId)
                        print("classId=",pastframeobj.classId)
                        print("objLabel=",pastframeobj.objLabel)
                        for objlist in pyds.NvDsPastFrameObjList.list(pastframeobj):
                            print('frameNum:', objlist.frameNum)
                            print('tBbox.left:', objlist.tBbox.left)
                            print('tBbox.width:', objlist.tBbox.width)
                            print('tBbox.top:', objlist.tBbox.top)
                            print('tBbox.right:', objlist.tBbox.height)
                            print('confidence:', objlist.confidence)
                            print('age:', objlist.age)
            try:
                l_user=l_user.next
                break
def draw_bounding_boxes(image, box, label, id_, color):
    x1 = int(box[0])
    y1 = int(box[2])
    x2 = int(box[1])
    y2 = int(box[3])
    image = cv2.rectangle(image, (x1, y1), (x2, y2), color, 2, cv2.LINE_4)
    image = cv2.putText(image, label+ f'-{id_}', (x1 - 10, y1 - 10),
                        cv2.FONT_HERSHEY_SIMPLEX, 0.5,
                        (0, 0, 255, 0), 2)
    return image
def main(args):
    # Check input arguments
    if(len(args)<2):
        sys.stderr.write("usage: %s <h264_elementary_stream> [0/1]\n" % args[0])
        sys.exit(1)
    # Standard GStreamer initialization
    if(len(args)==3):
        past_tracking_meta[0]=int(args[2])
    GObject.threads_init()
    Gst.init(None)
    # Create gstreamer elements
    # Create Pipeline element that will form a connection of other elements
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    # Source element for reading from the file
    print("Creating Source \n ")
    source = Gst.ElementFactory.make("filesrc", "file-source") # file_name
    if not source:
        sys.stderr.write(" Unable to create Source \n")
    # Since the data format in the input file is elementary h264 stream,
    # we need a h264parser
    print("Creating H264Parser \n")
    h264parser = Gst.ElementFactory.make("h264parse", "h264-parser") # .h264
    if not h264parser:
        sys.stderr.write(" Unable to create h264 parser \n")
    # Use nvdec_h264 for hardware accelerated decode on GPU
    print("Creating Decoder \n")
    decoder = Gst.ElementFactory.make("nvv4l2decoder", "nvv4l2-decoder") #
    if not decoder:
        sys.stderr.write(" Unable to create Nvv4l2 Decoder \n")
    # Create nvstreammux instance to form batches from one or more sources. #
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    # Use nvinfer to run inferencing on decoder's output,
    # behaviour of inferencing is set through config file
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie \n")
    tracker = Gst.ElementFactory.make("nvtracker", "tracker")
    if not tracker:
        sys.stderr.write(" Unable to create tracker \n")
    sgie1 = Gst.ElementFactory.make("nvinfer", "secondary1-nvinference-engine")
    if not sgie1:
        sys.stderr.write(" Unable to make sgie1 \n")
    sgie2 = Gst.ElementFactory.make("nvinfer", "secondary2-nvinference-engine")
    if not sgie1:
        sys.stderr.write(" Unable to make sgie2 \n")
    sgie3 = Gst.ElementFactory.make("nvinfer", "secondary3-nvinference-engine")
    if not sgie3:
        sys.stderr.write(" Unable to make sgie3 \n")
    # Add nvvidconv1 and filter1 to convert the frames to RGBA
    # which is easier to work with in Python.
    print("Creating nvvidconv1 \n ")
    nvvidconv1 = Gst.ElementFactory.make("nvvideoconvert", "convertor1")
    if not nvvidconv1:
        sys.stderr.write(" Unable to create nvvidconv1 \n")
    print("Creating filter1 \n ")
    caps1 = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
    filter1 = Gst.ElementFactory.make("capsfilter", "filter1")
    if not filter1:
        sys.stderr.write(" Unable to get the caps filter1 \n")
    filter1.set_property("caps", caps1)
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        sys.stderr.write(" Unable to create nvvidconv \n")
    # Create OSD to draw on the converted RGBA buffer
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    # Finally render the osd output
    if is_aarch64():
        transform = Gst.ElementFactory.make("nvegltransform", "nvegl-transform")
    print("Creating EGLSink \n")
    sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
    if not sink:
        sys.stderr.write(" Unable to create egl sink \n")
    print("Playing file %s " %args[1])
    source.set_property('location', args[1])
    streammux.set_property('width', 1920)
    streammux.set_property('height', 1080)
    streammux.set_property('batch-size', 1)
    streammux.set_property('batched-push-timeout', 4000000)
    #Set properties of pgie and sgie
    pgie.set_property('config-file-path', "yolov4_pgie_config.txt")
    sgie1.set_property('config-file-path', "dstest2_sgie1_config.txt")
    sgie2.set_property('config-file-path', "dstest2_sgie2_config.txt")
    sgie3.set_property('config-file-path', "dstest2_sgie3_config.txt")
    #Set properties of tracker
    config = configparser.ConfigParser()
    config.read('dstest2_tracker_config.txt')
    config.sections()
    for key in config['tracker']:
        if key == 'tracker-width' :
            tracker_width = config.getint('tracker', key)
            tracker.set_property('tracker-width', tracker_width)
        if key == 'tracker-height' :
            tracker_height = config.getint('tracker', key)
            tracker.set_property('tracker-height', tracker_height)
        if key == 'gpu-id' :
            tracker_gpu_id = config.getint('tracker', key)
            tracker.set_property('gpu_id', tracker_gpu_id)
        if key == 'll-lib-file' :
            tracker_ll_lib_file = config.get('tracker', key)
            tracker.set_property('ll-lib-file', tracker_ll_lib_file)
        if key == 'll-config-file' :
            tracker_ll_config_file = config.get('tracker', key)
            tracker.set_property('ll-config-file', tracker_ll_config_file)
        if key == 'enable-batch-process' :
            tracker_enable_batch_process = config.getint('tracker', key)
            tracker.set_property('enable_batch_process', tracker_enable_batch_process)
        if key == 'enable-past-frame' :
            tracker_enable_past_frame = config.getint('tracker', key)
            tracker.set_property('enable_past_frame', tracker_enable_past_frame)
    print("Adding elements to Pipeline \n")
    pipeline.add(source)
    pipeline.add(h264parser)
    pipeline.add(decoder)
    pipeline.add(streammux)
    pipeline.add(pgie)
    pipeline.add(tracker)
    pipeline.add(sgie1)
    pipeline.add(sgie2)
    pipeline.add(sgie3)
    pipeline.add(nvvidconv)
    pipeline.add(filter1)
    pipeline.add(nvvidconv1)
    pipeline.add(nvosd)
    pipeline.add(sink)
    if is_aarch64():
        pipeline.add(transform)
    if not is_aarch64():
        # Use CUDA unified memory in the pipeline so frames
        # can be easily accessed on CPU in Python.
        mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
        streammux.set_property("nvbuf-memory-type", mem_type)
        nvvidconv.set_property("nvbuf-memory-type", mem_type)
    # we link the elements together
    # file-source -> h264-parser -> nvh264-decoder ->
    # nvinfer -> nvvidconv -> nvosd -> video-renderer
    print("Linking elements in the Pipeline \n")
    source.link(h264parser)
    h264parser.link(decoder)
    sinkpad = streammux.get_request_pad("sink_0")
    if not sinkpad:
        sys.stderr.write(" Unable to get the sink pad of streammux \n")
    srcpad = decoder.get_static_pad("src")
    if not srcpad:
        sys.stderr.write(" Unable to get source pad of decoder \n")
    srcpad.link(sinkpad)
    streammux.link(pgie) # ---> yolov4_prob --> 4 cars, 1 car-> plate_detect -- > ocr
    pgie.link(tracker)  # ---> pose_prob --> 4 plates
    tracker.link(nvvidconv)
    # sgie1.link(sgie2)
    # sgie2.link(sgie3)
    # sgie3.link(nvvidconv)
    nvvidconv.link(nvosd)
    if is_aarch64():
        nvosd.link(transform)
        transform.link(sink)
    else:
        nvosd.link(sink)
    # create and event loop and feed gstreamer bus mesages to it
    loop = GObject.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect ("message", bus_call, loop)
    # Lets add probe to get informed of the meta data generated, we add probe to
    # the sink pad of the osd element, since by that time, the buffer would have
    # had got all the metadata.
    pgiebufferpad = pgie.get_static_pad("src")
    if not pgiebufferpad:
        sys.stderr.write(" Unable to get sink pad of pgie \n")
    pgiebufferpad.add_probe(Gst.PadProbeType.BUFFER, pgie_sink_pad_buffer_probe, 0)
    osdsinkpad = nvosd.get_static_pad("sink")
    if not osdsinkpad:
        sys.stderr.write(" Unable to get sink pad of nvosd \n")
    osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)# yolov4_detector / pass 2 person
#     osdsinkpad2.add_probe(Gst.PadProbeType.BUFFER, pose_estimation, 0) # single person
#     osdsinkpad3.add_probe(Gst.PadProbeType.BUFFER, tracker, 0)
    print("Starting pipeline \n")
    # start play back and listed to events
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except:
        pass
    # cleanup
    pipeline.set_state(Gst.State.NULL)
if __name__ == '__main__':
    sys.exit(main(sys.argv))
For every frame, the object id is unique
i need that for every objects in a single frame and how can i add or remove objects from buffer, only pass perticular objects to osd.
If you don’t want to display some objects, you may try to set the alpha value of the bbox to 0.
There is " border_color", “bg_color” in NvOSD_RectParams.
https://docs.nvidia.com/metropolis/deepstream/sdk-api/struct__NvOSD__RectParams.html
