You can refer to our demo deepstream_imagedata-multistream_redaction.py to get the frame array. It’s simillar to your code snippet. Then you need to calculate the data corresponding to the frame array based on the bbox coordinates.
def extract_face_region(frame_meta, obj_meta, buffer):
x, y, width, height = int(obj_meta.rect_params.left), int(obj_meta.rect_params.top), int(obj_meta.rect_params.width), int(obj_meta.rect_params.height)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
except StopIteration:
break
if frame_meta.num_obj_meta != 0:
l_obj = frame_meta.obj_meta_list
while l_obj is not None:
try:
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
break
if obj_meta.class_id == 0: # Adjust the class_id as needed
batch_id = frame_meta.batch_id
n_frame = pyds.get_nvds_buf_surface(buffer, batch_id)
# Extract the face region directly from RGBA format
face_region = n_frame[y:y + height, x:x + width, :]
# print("n_frame : ", type(face_region))
emotions = detect_emotion(face_region)
label = max(emotions, key=lambda x: emotions[x])
print("label : ", label)
return n_frame
try:
l_obj = l_obj.next
break
try:
l_frame = l_frame.next
break
return None
def detect_emotion(image):
with torch.no_grad():
# Normalise and transform images
normalize = transforms.Normalize(mean=[0.485, 0.456, 0.406],
std=[0.229, 0.224, 0.225])
x = []
try:
img = Image.fromarray(image)
transformed = transforms.Compose([
transforms.Resize(256),
transforms.CenterCrop(224),
transforms.ToTensor(),
normalize
])(img)
x.append(transformed)
except Exception as e:
print(f"Error processing image: {e}")
if len(x) > 0:
# Stack the transformed images into a tensor
x = torch.stack(x)
# Feed through the model
y = emo_model(x)
for i in range(y.size()[0]):
# Add emotion to result
try:
emots = {}
for key, emot in enumerate(list(emotions_labels)):
emots[emot] = round(100 * y[i][key].item(), 2)
print(emots)
return emots
return False
return False
i am getting a Segmentation fault (core dumped) when i try to access the ‘n_frame’. Even when i try to print "n_frame’ i am getting a segmentation fault.
