Trying to build Isaac ROS docker image according to: Isaac ROS Dev — isaac_ros_docs documentation
And per the “Prebuilt Images” section of the same page ( Isaac ROS Dev — isaac_ros_docs documentation ), run_dev.sh pulls prebuilt images from nvcr.io.
I have logged in to nvcr.io: according https://org.ngc.nvidia.com/account/api-key:
docker login nvcr.io
Username: $oauthtoken
Password:
WARNING! Your credentials are stored unencrypted in '/home/tige/.docker/config.json'.
Configure a credential helper to remove this warning. See
https://docs.docker.com/go/credential-store/
Login Succeeded
However run_dev.sh tries to build the image instead:
Checking if base image nvcr.io/isaac/ros:aarch64-ros2_humble_4c0c55dddd2bbcc3e8d5f9753bee634c exists on remote registry
Checking if base image nvcr.io/isaac/ros:aarch64_dc1c0c51db74acc2dcbfbc65dbf31d2d exists on remote registry
Building /home/.../workspaces/isaac_ros-dev/isaac_ros_common/scripts/../docker/Dockerfile.aarch64 as image: aarch64-image with base:
I try to do docker manifest inspect:
docker manifest inspect nvcr.io/isaac/ros:aarch64-ros2_humble_4c0c55dddd2bbcc3e8d5f9753bee634c
Get "https://nvcr.io/v2/isaac/ros/manifests/aarch64-ros2_humble_4c0c55dddd2bbcc3e8d5f9753bee634c": denied: {"errors": [{"code": "DENIED", "message": "Access Denied"}]}
Although I can fetch some other packages from nvcr.io:
docker manifest inspect nvcr.io/nvidia/pytorch:26.05-py3
"schemaVersion": 2,
"mediaType": "application/vnd.docker.distribution.manifest.list.v2+json",
"manifests": [
"mediaType": "application/vnd.docker.distribution.manifest.v2+json",
"size": 15439,
"digest": "sha256:ca73b4795f0d3ae27e9cd81b1b1f1b7fc6c0a129f7d51a359d2326e95af48a3d",
"platform": {
"architecture": "amd64",
"os": "linux"
"size": 15446,
"digest": "sha256:aa400d4373fa71f30e1714664beabcc64c2d198e72d65e9a3641440b07e7cc83",
"platform": {
"architecture": "arm64",
"os": "linux"
(Aboce packge is from: NVIDIA NGC → NVIDIA Developer Program → Launch → PyTorch Container (PyTorch | NVIDIA NGC) )
I could get the base image nvcr.io/nvidia/12.6.11-devel:12.6.11-devel-aarch64-ubuntu22.04 as well.
