Access past frames of tracked objects given nvtracker
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.4
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 535
• Issue Type( questions, new requirements, bugs) questions
**• How to reproduce the issue?
Hi, I am referring deepstream_test_2 to access past data of tracked objects. However, in my case, I want to extract past frames of tracked bounding boxes in np.ndarary format, to run action recognition. For example, for each tracked objects, it is required to have np.ndarray frames of past bounding boxes, so that 16x224x224x3 (16 frames of 224x224x3 images) can be used for inference. How should I modify the example for this purpose? Thank you.
You need to implement your own algorithms using nvdspreprocess like deepstream-pose-classification.
