Access pixels from MIPI camera
I am going to receive a new camera, the FSM-IMX304M (https://www.framos.com/media/pdf/c4/bf/05/FSM-IMX304_Datasheet_v1-0g_BriefDPJ6pgNMQObQQ.pdf) The bit depth is 12, the chromacity is mono.
I need to access at each pixel one by one.
From my reading and discussions, when we call :
getImage()
the buffer is filled like that :
|              16 bits                          |
D5-D4-D3-D2-D1-D0-D11-D10-0-0-D11-D10-D9-D8-D7-D6
To obtain the value of each pixel, I have to change the bitmap like that :
D5-D4-D3-D2-D1-D0-D11-D10-0-0-D11-D10-D9-D8-D7-D6 → D0-D1-D2-D3-D4-D5-D6-D7-D8-D9-D10-D11
Is it right ?
Notice that I use a streamlined V4L2.
Thank you for your help
Hi @anon79190853,
From the TRF (Technical Reference Manual), section 27.10.6 RAW Memory Formats, you can refer to the following image
So, indeed for a bit depth of 12, the valid data are the bits D0-D1-D2-D3-D4-D5-D6-D7-D8-D9-D10-D11
Regards,
Fabian
www.ridgerun.com
Hi Fabian,
Thank for your answer.
It is my first time and I do not have access to pixel’s value …
I use V4L2 to capture image.
First problem :
The resolution of my camera is 4112*3008. The pixel format is RG12, and it is monochrome sensor. I expect a .raw of 24737792 B, but it is 25411584 B. This difference is from padding, but what it is exactly ?
Second problem :
To read pixel value, first I cast the void* by an unsigned short*. Then, I just remove the MSB replicate :
unsigned short GetPixel(const void* data, const int heightIndice, const int widthIndice)
unsigned short* pixel = (unsigned short*) data ;
unsigned short mask = 16364 ;
pixel[heightIndicewidth+widthIndice] = pixel[heightIndicewidth+widthIndice] & mask ;
return pixel[heightIndice*width+widthIndice] ;
For example, if I want the read the pixel[i,j], I call the function like that :
unsigned short value = GetPixel(buffer, i, j) ;
My code doesn’t work because of padding (I hope), but is it the right method ?
Thank you
