For some reason, I need to enable SPI controller driver in ATF-bl31(Arm-trusted-firmware) or Trusty on Jetson AGX Xavier. I am using public Jetson R32.2.3 release code(ATF/Trusty/Cboot).
Since the BPMP driver(in ATF) only supports SE, I ported the BPMP-FW interface code from Cboot to ATF.
I wrote a simple code to init. the IPC and configured the clock settings for SPI1, it works in Cboot (accesses SPI1 OK) . But when ATF-bl31 accesses the SPI1 I/O range (0x03210000~), it hangs.
The procedures including: 1. tegrabl_ipc_init(), 2. tegrabl_car_rst_set(), 3. tegrabl_car_clk_enable() , 4. tegrabl_car_set_clk_src(), 5. tegrabl_car_set_clk_rate(), 6. tegrabl_car_rst_clear().
The major difference are BPMP_IPC_TX(RX)_PHY_BASE(0x4004C000/0x4004D000 in ATF/Trusty, 0x4004E000/0x4004F000 in Cboot)
Could Nvidia Engineer tell me what else needs to be done before accessing the SPI controller in ATF-bl31/Trusty? Thank you.
