Access tools that are in Parabricks 3.8.0
Hi
I want to get access to Parabricks 3.8.0 where the WGS pipeline that has Strelka and is streamlined with VCF QC, VCF merge and multiple annotation dbs. I did download the archive docker file to run on Singularity but it didn’t work.
Best
Yot
Hi Yot,
I strongly don’t recommend you try Parabricks 3.8.0 because it’s outdated and not under maintenance any more. The tools that you mentioned in 3.8.0 were not optimized on GPU, so if you just switch to the open source version you won’t see huge performance loss.
