Hi there,
I have created the following struct with methods(getter/setter) to access that struct members in my CU file as shown below:-
struct XYZ
float3 point[5],
short value[5];
device void SetPointByIndex(int index,float3 fpoint)
point[index]=fpoint;
device void SetValueByIndex(int index,short sval)
value[index]=sval;
device float3 getPoint(int index)
return point[index];
device short getValue(int index)
return value[index];
now, i am making the instance of this struct in my global kernel method…
global void kernelmethod()
XYZ a;
//set the value of a
a.SetPointByIndex(0,some_float3_value);
device_func(a); //this is device function.
device_func2(a);
i am calling various device function from the kernelmthod();
now the problem is when i try to access the value of a from device functions i am getting garbage result but I can get the value inside global function.
Also i can’t change all the function to global as it is not allowed to call one global function inside another global function. ( is this true?)
so what are my option to pass my own object type among the global and device function…
thank you
miztaken
