Access `watch_source_status` from python binding
• Hardware Platform (Jetson / GPU): dPU A40.
• DeepStream Version: 6.4-triton-multiarch.
• TensorRT Version: 8.6.1.6.
• NVIDIA GPU Driver Version (valid for GPU only): 535.146.02.
• Issue Type( questions, new requirements, bugs): questions.
How i can access watch_source_status from python binding to check if rtsp source is disconnected based on buffer’s time.?
rtspsrc posts an error in the GStreamer bus when it gets disconnected. You can add a bus handler with Gst.Bus.add_signal_watch_full.
If you need to reconnect after rtsp is disconnected, it is recommended to use nvurisrcbin.
No python binding required.
I want to reconnect specific number of trying not all the time, Can do that via nvurisrcbin?
Yes, of course. View the definition of rtsp_reconnect_attempts through gst-inspect-1.0 nvurisrcbin
I don’t found rtsp_reconnect_attempts through gst-inspect-1.0 nvurisrcbin from my side, and after apply grep
Sorry, I made a mistake, this is a feature that will be released in the next version.
There is a workaround for the moment.
After reconnecting for the specified number of times, set rtsp-reconnect-interval to 0
How I can do this?
Count the number of reconnections in your app, and then write code such as nvurisrcbin.set_property('rtsp-reconnect-interval', 0)
How I can do this via deepstream_test3 python code?
Below is a simple example for your reference. If there is no data for 3 seconds, it is considered that a reconnection has occurred.
Or you can wait for the next version to be released
diff --git a/apps/deepstream-test3/deepstream_test_3.py b/apps/deepstream-test3/deepstream_test_3.py
index 75a64d5..16eb8b7 100755
--- a/apps/deepstream-test3/deepstream_test_3.py
+++ b/apps/deepstream-test3/deepstream_test_3.py
@@ -145,17 +145,48 @@ def cb_newpad(decodebin, decoder_src_pad,data):
         else:
             sys.stderr.write(" Error: Decodebin did not pick nvidia decoder plugin.\n")
+buffer_time = 0
+reconnect_interval = 3
+reconnect_count = 0
+max_reconnect_count = 3
+loop = None
+def rtspsrc_monitor_probe_func(pad, info, u_data):
+    if info.type & Gst.PadProbeType.BUFFER:
+        global buffer_time
+        buffer_time = time.time()
+    if info.type & Gst.PadProbeType.EVENT_DOWNSTREAM:
+        pass
+    return Gst.PadProbeReturn.OK
 def decodebin_child_added(child_proxy,Object,name,user_data):
     print("Decodebin child added:", name, "\n")
-    if(name.find("decodebin") != -1):
+    if (name.find("decodebin") != -1):
         Object.connect("child-added",decodebin_child_added,user_data)
+    if "depay" in name:
+        print(f"depay ......")
+        depay_element = child_proxy.get_by_name("depay")
+        depay_element_sinkpad = depay_element.get_static_pad("sink")
+        GLib.timeout_add_seconds(1, watch_source_status, None)
+        depay_element_sinkpad.add_probe(Gst.PadProbeType.BUFFER | Gst.PadProbeType.EVENT_DOWNSTREAM, rtspsrc_monitor_probe_func, 0)
     if "source" in name:
         source_element = child_proxy.get_by_name("source")
         if source_element.find_property('drop-on-latency') != None:
             Object.set_property("drop-on-latency", True)
+def watch_source_status(user_data):
+    current_time = time.time()
+    delta = current_time - buffer_time
+    print(f"delta {delta}")
+    if delta > reconnect_interval:
+        reconnect_count += 1
+        if reconnect_count > max_reconnect_count:
+            print("reconnect too many ")
+    return True
 def create_source_bin(index,uri):
     print("Creating source bin")
@@ -171,11 +202,12 @@ def create_source_bin(index,uri):
     # Source element for reading from the uri.
     # We will use decodebin and let it figure out the container format of the
     # stream and the codec and plug the appropriate demux and decode plugins.
-    if file_loop:
+    if file_loop or True:
         # use nvurisrcbin to enable file-loop
         uri_decode_bin=Gst.ElementFactory.make("nvurisrcbin", "uri-decode-bin")
-        uri_decode_bin.set_property("file-loop", 1)
+        # uri_decode_bin.set_property("file-loop", 1)
         uri_decode_bin.set_property("cudadec-memtype", 0)
+        uri_decode_bin.set_property('rtsp-reconnect-interval', reconnect_interval)
     else:
         uri_decode_bin=Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
     if not uri_decode_bin:
@@ -186,6 +218,7 @@ def create_source_bin(index,uri):
     # callback once a new pad for raw data has beed created by the decodebin
     uri_decode_bin.connect("pad-added",cb_newpad,nbin)
     uri_decode_bin.connect("child-added",decodebin_child_added,nbin)
+    # uri_decode_bin.connect("deep-element-added",decodebin_deep_element_added,nbin)
     # We need to create a ghost pad for the source bin which will act as a proxy
     # for the video decoder src pad. The ghost pad will not have a target right
@@ -386,7 +419,7 @@ def main(args, requested_pgie=None, config=None, disable_probe=False):
         print(i, ": ", source)
     print("Starting pipeline \n")
-    # start play back and listed to events
+    # start play back and listed to events
     pipeline.set_state(Gst.State.PLAYING)
     try:
         loop.run()
