Hey guys,
I’m trying to access a DXVA NV12 IDirect3D9Surface via CUDA like this:
void TestDxvaCudaInterop(IDirect3DDevice9* d3d9Device)
IDirectXVideoProcessorService* dxvaProcessorService = NULL;
IDirect3DSurface9* nv12Surface = NULL;
CUcontext cudaContext;
CUdevice cudaDevice;
CUgraphicsResource nv12cuda;
cuD3D9CtxCreate(&cudaContext, &cudaDevice, CU_CTX_SCHED_BLOCKING_SYNC, d3d9Device);
DXVA2CreateVideoService(d3d9Device, __uuidof(IDirectXVideoProcessorService), (void **) &dxvaProcessorService);
dxvaProcessorService->CreateSurface(256, 256, 0, (D3DFORMAT) MAKEFOURCC('N', 'V', '1', '2'), D3DPOOL_DEFAULT, 0, DXVA2_VideoProcessorRenderTarget, &nv12Surface, NULL);
if ((nv12Surface) && (cuGraphicsD3D9RegisterResource(&nv12cuda, nv12Surface, CU_GRAPHICS_REGISTER_FLAGS_NONE) == CUDA_ERROR_INVALID_HANDLE))
MessageBox(0, "invalid handle", "error", 0);
Unfortunately that doesn’t work (CUDA_ERROR_INVALID_HANDLE), at least not on my current development system:
win7 x64, 9400 mainboard, driver 306.23, cuda 5.0.1 driver
Does anybody know a way to make this work? FWIW, I know that I could transfer the data to CPU RAM, then back to GPU RAM, to work around the problem, but that’s not really acceptable due to performance reasons. I know I could also convert the NV12 surface to RGB, but that’s not acceptable, either, because I want to run my own algorithms for chroma upsampling and color conversion.
FWIW, I can access DXVA NV12 surfaces just fine with AMD GPUs, using the latest beta drivers and the OpenCL 1.2 D3D9 interop extension.
