Accessing GPio using jetson nano with qt creator
I have written a code for accessing gpio in jetson nano , written in terminal, how should it run in qt for jetson nano , the code is enclosed hereby:
// Handles input and output
#include <iostream>
// For delay function
#include <chrono>
// Handles threads of program execution
#include <thread>
// Signal handling
#include <signal.h>
#include <JetsonGPIO.h>
// Pin Definitions
int led_pin = 7;
// Flag to determine when user wants to end program
bool done = false ;
// Function called by Interrupt
void signalHandler ( int s){
done = true ;
int main() {
// When CTRL+C pressed, signalHandler will be called
// to interrupt the programs execution
signal (SIGINT, signalHandler);
// Pin Definitions
GPIO::setmode(GPIO::BOARD);
// LED pin gets set to high initially
GPIO::setup(led_pin, GPIO::OUT, GPIO::HIGH);
std::cout << "Press CTRL+C to stop the LED" << std::endl;
int curr_value = GPIO::HIGH;
// Blink LED every 0.5 seconds
while (!done) {
std::this_thread::sleep_for(std::chrono::milliseconds(500));
GPIO::output(led_pin, curr_value);
std::cout << "LED is ON" << std::endl;
curr_value = GPIO::LOW;
std::cout << "LED is OFF" << std::endl;
GPIO::cleanup();
return 0;
hello walihullah,
I don’t have experience with QT creator.
but, please refer to below thread to resolve the issue, Jetson.GPIO not working on Python inside the container.
Hi @walihullah ,
We have controlled by using system commands with qt creator. Our gpio numbers were 508,509 and 510. You should enter your gpio numbers.
system("echo 508 > /sys/class/gpio/export");
system("echo out > /sys/class/gpio/gpio508/direction");
system("echo 509 > /sys/class/gpio/export");
system("echo out > /sys/class/gpio/gpio509/direction");
system("echo 510 > /sys/class/gpio/export");
system("echo out > /sys/class/gpio/gpio510/direction");
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
