I am trying to access the output masks of my maskrcnn model as numpy arrays following the deepstream-segmentation python example, but the frame_meta.frame_user_meta_list is always None.
I am using the new version output parser for the maskrcnn NvDsInferParseCustomMrcnnTLTV2 and this is my config file config_infer_primary_mrcnn.txt (2.2 KB)
Any help would be appreciated, thank you.
**• Hardware Platform ** Jetson AGX Xavier • DeepStream Version deepstream 5.1 • JetPack Version (valid for Jetson only) Jetpack 4.5.1 • TensorRT Version Tensorrt 7.1.3
Yes, i also have to clarify that in my case described above, even though frame_meta.frame_user_meta_list is none, the model does output masks and detections and they are visible on the output frames, so my model works well, i just can’t access the metadata.
It’s expected since the meta data will be released after nvosd, can you install the probe on the sink of nvosd or any upstream plugin to see if you can access it?
Can you try the C version example on my first example and then export it to python?
Also keep in mind mask rcnn is instance segmentation while the python segmentation is semantic segmentation, you should not expect the python sample work since they are different types of models
I did try the C version examples, they work fine with my model as a pipeline but i still can’t access the meta data even in the C examples.
I know instance segmentation is different but i assumed that the segmentation meta data whether it’s semantic or instance would still be stored in the frame_meta.frame_user_meta_list.
If that’s not the case, then where should i be looking for the masks metadata for instance segmentation models?
Tried that one too in python, i got the following error
TypeError: Unable to convert function return value to a Python type! The signature was
(self: pyds.NvDsObjectMeta) -> _NvOSD_MaskParams
Does this mean that the Mask metadata cannot be accessed from python?
Update:
I tried to access the mask info in C, i was able to access it, but i am not sure i understand the values or if these are the values i am looking for. According to the NvOSD_MaskParams documentation, the available data are just the size, threshold, width and height of the mask not the actual mask, Unless i am missing something.
