but I got fetching error failed. So I tried to search for solution and I found that I have to do
sudo apt-get remove .*:arm64
Unfortunately it is for the host machine, I ran that command on my Jetson TX2. Now I think everything that has been installed were accidentally removed. Is there any way to restore all the deleted file? Thanks
You can still clone the rootfs partition before a flash if you have something valuable you need to save. The clone produces a “backup.img” file you can delete (a sparse file), plus a “backup.img.raw” file which can be loopback mounted and examined.
