When reading som with customize BSP I get Machine model: Jetson-AGXi instead of AGX.
The logs were taken from 2 different Nvidia’s Xavier commercial.
the logs are:
evb.log (70.0 KB)
SystemWIthCustomizeBsp.log (62.2 KB)
What can be the cause for this issue or should I ignore this?
You can try to clean up your log format first…
What is the exact log you want to ask here?
I am asking why the machine model is [ 0.000000] Machine model: Jetson-AGXi instead ofJetson-AGX
From what I saw, because the board you are using there is really a AGXi.
If it is not, please share me the result of
root@tegra-ubuntu:/home/nvidia# i2cdump -y 0 0x50
I am using Xavier commercial.
the i2c dump is :
No size specified (using byte-data access)
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 01 00 ff 00 48 0b 04 00 04 52 00 00 00 00 00 00 ?...H??.?R......
10: 00 00 00 00 36 39 39 2d 38 32 38 38 38 2d 30 30 ....699-82888-00
20: 30 34 2d 34 30 30 20 52 2e 30 00 00 00 00 00 00 04-400 R.0......
30: 00 00 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
40: ff ff ff ff 00 09 79 2d b0 48 31 34 32 31 38 32 .....?y-?H142182
50: 32 30 32 34 32 32 32 00 00 00 00 00 00 00 00 00 2024222.........
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
90: 00 00 00 00 00 00 4e 56 43 42 1c 00 4d 31 00 00 ......NVCB?.M1..
a0: ff ff ff ff ff ff ff ff ff ff ff ff 00 09 79 2d .............?y-
b0: b0 48 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ?H..............
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 38 ...............8
Do you have NVIDIA devkit on your side that can test?
Please put that problematic module to NV devkit, flash the board with sdkmanager and share me the full boot up log.
system
Closed
November 20, 2023, 9:08am
11
