Account-wide 429 Too Many Requests — persists even on isolated single requests
Subject: Account-wide 429 “Too Many Requests” — persists even on isolated single requests
Hello NVIDIA Support Team,
I’m running into a persistent HTTP 429 “Too Many Requests” error across my entire NVIDIA NIM account. This isn’t a normal rate-limit situation — I’ve isolated the issue completely:
- Tested with a standalone Python script (no application, no agent, no loop) — same 429.
- Tested with a single, one-off request after waiting several minutes with zero other calls — same 429.
- Tested across multiple different models (minimaxai/minimax-m3 and moonshotai/kimi-k3) — same 429 on both.
- Tested via NVIDIA’s own build.nvidia.com playground with the same account — works fine there, which suggests the issue is specific to API key access, not the account being blocked outright.
This rules out normal RPM throttling, since a single isolated request shouldn’t trigger it. It looks like either a stuck/incorrect rate-limit flag on my account, or an issue with how this specific API key is provisioned.
Account details:
- Registered email: neuxswgd@gmail.com
- API Key ID (last 4 chars): QK-Wt
- Use case: Personal development — testing an AI coding agent (Hermes) for coursework/hobby projects
- Verified account status: phone-verified
Could someone please check whether there’s a stuck rate-limit state on this account or key, and let me know what’s needed to resolve it? Happy to provide more logs/timestamps if useful.
Thank you for your time.
Edit: To clarify, my account is fully phone-verified, so this doesn’t appear to be a standard unverified-account limit — it looks like a stuck rate-limit state or provisioning issue specific to this key/account.
