I trained the SSD-mobilenet v1 model for a custom dataset using the PyTorch codes provided with the jetson-inference repository but when I converted it into the TRT model using the given method, F1 score drops from 76% to 49%. Is there any cause or workaround to avoid this accuracy drop?
@dusty_nv I hope you can again help me here.
Hi @ash.hemax, not sure based on your dataset and how you are evaluating the F1 score, but my suggestions would be the same as your other thread:
