Hi!
I have some issue with the accuracy of image classification.
For the Face-Recongnition which I found at here:
[url]https://github.com/AastaNV/Face-Recognition[/url],
I have train my own set of data out. Using me and my friends face, however when there is 2 or more people in the data set it only shows two result only. I check with my classification model before merging (detection and classify) it works perfectly fine.
But when I merge it with the detection model, the accurately drop significantly. In digits, it is still able to show the result but not the same as the classification model. When I deploy it out, it only shows two results only. Below is an example to elaborate my case.
Example:
I train person A, B, C and D faces, for classification model it is able to accurately differentiate who is who. However, when I merge it with facial detection. Once it detect the face, it only shows person A or B results only even when it detect person C or D.
Hi AastaLLL,
Thanks for the information.
For the detection output, I check and it is working fine.
For the recognition plugin I am not sure what to check, for the plugin I never changed anything from the your source and for my case is the same facial recognition just that I train my own data out instead of using the celebrity data set.
Could you check if this function works correctly with your label file?
[url]Face-Recognition/face-recognition.cpp at master · AastaNV/Face-Recognition · GitHub
Hi AastLLL,
Yup, I checked and its working correctly. Just that the accuracy of the classification when merged is not very high (around 30% accuracy) as compare to just classification model( around 90 to 99%).
Do you use the same image content/resolution to test?
There is a ROI step between detection and classification, which may slightly lower the accuracy since re-sampling.
Could you check if accuracy drop is from this procedure?
Hi AastaLLL,
- Yes I used the same image content to test and the accuracy is still low, it only shows the desired result when e.g I stand at certain places.
- Yes, I checked and it came from here.
Here are some improvement can try:
1. Downscale implementation:
Simple bilinear is used for downscaling an image for classification.
[url]https://github.com/AastaNV/Face-Recognition/blob/master/kernel.cu#L101[/url]
2. Mean subtraction:
We don’t apply mean subtraction for the input of classification. (=ROI output)
If you have a pixel-wise mean subtraction, this may cause accuracy drop.
It’s recommended to save the output of ROI as an image and feed it into the classification-only pipeline for information.
