I use yolov3. Trained with the parameter letter_box = 1
. In testing, I use the key -letter_box
and I’m happy with the result.
When I use deeppstream I use the key maintain-aspect-ratio = 1
. And as a result, objects that come in contact with the bottom edge of the image are not marked as objects. If I use the key maintain-aspect-ratio = 0
, then these objects are marked with a bounding box. But at the same time, overall accuracy drops.
my code:
static std::vector<NvDsInferParseObjectInfo>
nonMaximumSuppression(const float nmsThresh, std::vector<NvDsInferParseObjectInfo> binfo, const uint& netW, const uint& netH)
auto overlap1D = [](float x1min, float x1max, float x2min, float x2max) -> float {
if (x1min > x2min)
std::swap(x1min, x2min);
std::swap(x1max, x2max);
return x1max < x2min ? 0 : std::min(x1max, x2max) - x2min;
auto computeIoU
= [&overlap1D](NvDsInferParseObjectInfo& bbox1, NvDsInferParseObjectInfo& bbox2) -> float {
float overlapX
= overlap1D(bbox1.left, bbox1.left + bbox1.width, bbox2.left, bbox2.left + bbox2.width);
float overlapY
= overlap1D(bbox1.top, bbox1.top + bbox1.height, bbox2.top, bbox2.top + bbox2.height);
float area1 = (bbox1.width) * (bbox1.height);
float area2 = (bbox2.width) * (bbox2.height);
float overlap2D = overlapX * overlapY;
float u = area1 + area2 - overlap2D;
return u == 0 ? 0 : overlap2D / u;
std::stable_sort(binfo.begin(), binfo.end(),
[](const NvDsInferParseObjectInfo& b1, const NvDsInferParseObjectInfo& b2) {
return b1.detectionConfidence > b2.detectionConfidence;
std::vector<NvDsInferParseObjectInfo> out;
std::vector<NvDsInferParseObjectInfo> out_out;
for (auto i : binfo)
bool keep = true;
for (auto j : out)
if (keep)
float overlap = computeIoU(i, j);
keep = overlap <= nmsThresh;
else
break;
if (keep)
out.push_back(i);
//out_out.push_back(i);
float centerx = i.left + (i.width / 2);
float centery = i.top + (i.height / 2);
float side = std::min(std::min(netW - 1, netH - 1), std::max(i.width, i.height));
i.left = std::max(centerx - (side / 2),float(0.0));
i.top = std::max(centery - (side / 2),float(0.0));
i.width = side;
i.height = side;
//i.left = clamp(i.left, 1, (netW - 1));
//i.top = clamp(i.top, 1, (netH - 1));
printf("points: %i, %i, %i, %i, wh: %i, %i\n",int(i.left), int(i.top), int(i.left+i.width), int(i.top+i.height), int(i.width), int(i.height));
if ((i.left+i.width) > netW) {
i.left = i.left + (netW - 1 - (i.left + i.width));
printf(" change left %i\n", int(i.left));
if ((i.top+i.height) > (netH-1)) {
i.top = i.top + (netH - 1 -(i.top + i.height));
printf(" change top %i\n", int(i.top));
if (i.left < 0) {
i.left = 0;
if (i.top < 0) {
i.top = 0;
return out_out;
