ACE-Step v1.5 on DGX Spark — install recipe, measured numbers, and the scheduling finding I'd have wanted before I started
Hey everybody, Arthur here. I’ve been digging this forum and the amazing information that everybody is sharing, and I’ve been getting a lot of benefit from it, so I thought I would try to give back. It’s not anything super special at all, and i’m having my local friend help me write it up, since I hardly know how to tie my own shoes anymore and I definitely don’t really have much of an idea what I’m doing.. but if you are interested in a cheap way to generate some great music on our little boxes, well.. i haven’t seen anybody else mention this setup yet so I thought I would.. so now for the slop portion, let me know if it helps
Two Sparks here (Asus Ascent GX10s): one serving an LLM for reasoning/coding and embedding, one doing generative media. The media box runs ACE-Step v1.5 alongside ComfyUI as the backend for a personal agent OS, so this is a “production” setup rather than a weekend benchmark.
I came looking for ACE-Step numbers on GX10 and found none — no VRAM figure, no generation time, no install notes. So here’s everything, including one finding that changed how I schedule the thing entirely.
The install
Plain systemd unit, uv-managed venv, no container:
ini
# /etc/systemd/system/acestep.service
[Unit]
Description=ACE-Step music API (:8002)
After=network-online.target
Wants=network-online.target
[Service]
User=arthur
WorkingDirectory=/home/arthur/ACE-Step-1.5
ExecStart=/home/arthur/.local/bin/uv run acestep-api --port 8002 --host 0.0.0.0
Restart=always
RestartSec=10
EnvironmentFile=-/home/arthur/ACE-Step-1.5/.env
[Install]
WantedBy=multi-user.target
# .env
ACESTEP_CONFIG_PATH=acestep-v15-turbo
ACESTEP_LM_BACKEND=vllm
ACESTEP_LM_MODEL_PATH=acestep-5Hz-lm-4B
ACESTEP_DEVICE=auto
ACESTEP_INIT_LLM=auto
The v1.5 turbo variant, with the 4B lyrics model served through vLLM. Stating that because the existing thread speculates about which variants fit — this one runs comfortably alongside ComfyUI with room to spare. Once they have the full model out, that should fit too. Uptime when I measured: 10 days, 20 hours. No restarts.
It’s an async task API: POST /release_task → poll POST /query_result → fetch the path. One gotcha that cost me a wrong diagnosis: the result row’s result field is a JSON string you have to parse before the audio path is visible inside it. Read the row’s top level and you get nothing, which looks exactly like a failed encode — I went looking for a dead ffmpeg that was never dead.
Memory
idle 15,140 MiB
peak during generation 15,172 MiB
~30 MB of swing. The model sits resident and generating barely moves it.
Timing: it’s fixed cost, not real-time factor
120s audio, 8 steps, warm, box otherwise idle:
run thinking wall
A1 true 12.4 s
A2 true 34.1 s
B1 false 7.8 s
B2 false 8.8 s
30-second track false 7.9 s
A 30-second track and a 120-second track take the same wall clock. Which means RTF is a misleading way to describe this model — the identical run reads as 15× realtime at 120s and 3.8× at 30s. The honest figure is “~8 seconds per generation, largely independent of length.”
Separately: thinking:true is the entire source of timing variance. Same seed, same prompt — 2.7× spread with it on, 1.1× with it off. That’s the vLLM lyrics model doing variable-length generation; the diffusion side is very consistent. If anything downstream cares about latency, that’s the knob.
⭐ The finding: ACE-Step queues, it does not batch
(this really may not be news)
I submitted N generations simultaneously and recorded when each one finished, because a total can be explained two ways and a finish-time distribution can’t.
N wall per-track finish times (s) peak mem
1 10.6s 10.6s 10.6 15,162 MiB
2 15.7s 7.8s 9.3, 15.7 15,172 MiB
4 33.1s 8.2s 7.9, 14.9, 26.0, 33.1 15,172 MiB
8 74.8s 9.3s 6.8, 14.0, 24.5, 31.8, 39.7, 52.0, 61.8, 74.8 15,172 MiB
Evenly staggered ~7–9s apart. A conveyor belt. And peak memory never moves — 15,162 → 15,172 MiB from N=1 to N=8. A batching engine’s memory grows with batch size; this one doesn’t, because only one generation is ever in flight. Two independent signals, same answer. All files landed (8/8), so work is queued rather than refused.
Per-track is flat at ~8–9s regardless of N. Throughput ceiling ≈ 7 tracks/minute, however you submit.
thinking:true doesn’t amortise either — 18.3s per track at N=4 vs 8.2s with it off. ACE-Step serialises upstream of its vLLM lyrics model, so vLLM’s batching never engages.
What that means in practice
Put the two findings together and it’s a real scheduling decision:
  • one 120s track → ~8s → 15× realtime
  • eight 30s tracks → same 240s of audio in ~68s → 3.5× realtime
Same audio, 4× the wall clock, purely from how you chopped it. Generate long and cut down. Don’t fan out, don’t generate short. I was doing the wrong one.
Co-residency: two generative workloads, one box
service GPU memory
ACE-Step v1.5 15,140 MiB
ComfyUI (Flux 2 / LTX 2.3 stack) 37,566 MiB
resident together ~52.7 GB
All the ACE-Step numbers above were taken with ComfyUI resident throughout.
Caveat: ComfyUI was loaded but idle. I have not measured ACE-Step under active image or video generation, and others here report image generation slowing 5–6× under contention — so I wouldn’t assume it’s free.
For contrast, the other Spark
Worth putting beside it (maybe, probably not), because the answer is the opposite. Same owner, same week, second box — vLLM 0.23.0 serving the Ornith 35B NVFP4 model from Balaxxe (who is a legend to me already), 128K context:
concurrency aggregate per-stream
1 38.4 tok/s 38.4
2 79.6 39.8 ↑
8 222.0 27.7
32 486.1 tok/s 15.1
12.6× scaling, and it hadn’t plateaued at 32. At N=2 per-stream actually rises — the classic bandwidth-bound signature, one weight read amortised across two sequences.
So on the same hardware: vLLM scales 12.6× with fan-out, ACE-Step scales 1.0×. If you’re building a scheduler across both, that difference is the whole design.
One incidental datapoint for the sm_121 discussion: that container’s torch.cuda.get_arch_list() returns sm_80, sm_90, sm_100, sm_110, **sm_120** — not bare sm_121. So the official vllm/vllm-openai image is built the safe way for GB10.
Caveats
  • Driver 595.71.05 on the media box, which I gather is well past supported. (The other box is on 580.159.03 and behaves the same in every way I measured, including nvidia-smi --query-gpu=memory.used returning [N/A] on both — so that’s a GB10 unified-memory characteristic, not a driver symptom. Per-process via --query-compute-apps works fine.)
  • Ubuntu 24.04.4, aarch64, DGX OS 7.5.0.
  • No quantization on ACE-Step. Given what NVFP4 W4A4 has done for diffusion here, I’d be curious whether anyone has tried the equivalent.
Offer
If there’s a parameter combination, duration, or contention scenario you want measured, I’ll run it — the box is set up and it costs minutes. I’d rather this category had numbers in it than impressions, and I’m only able to contribute because other people’s install notes here saved me days.
Happy to share the proxy that wraps the async polling, and the measurement scripts, if either is useful.
ACE-Step 1.5 + LTX-2.3 on the DGX Spark: a full lip-synced music video in one ComfyUI workflow
Following up on your ACE-Step thread I wanted to try something fun… basically generating a complete song including a music video whose singer is lip-synced to that song, in a single ComfyUI run on the spark-comfyui build.
Measured on my Spark, end to end, one click:
2:28 music video   1280x704, 24 fps, 3552 frames, 37 chained segments
song               ACE-Step 1.5 XL base, 2m05s
video              LTX-2.3 22B dev fp8 + distilled LoRA, 30m11s (~49s per 4s segment)
total              32m16s
See the video here: https://youtu.be/YV7zDKkkeBI
Anyway… have fun - hope you can use it.
I had to create a custom node for the stitching, otherwise it’s just the standard spark-comfyui build.
Step 1: install spark-comfyui
The whole tuned stack lives in a docker image: cu130 PyTorch, SageAttention compiled natively for sm_121, GPU onnxruntime, plus the GB10 patches. Your models and outputs stay in a plain data/ directory next to the script.
git clone https://github.com/bjarkebolding/spark-comfyui.git
cd spark-comfyui
./spark-comfyui.sh install          # one-time image build, 10-30 min
Check it came up healthy:
./spark-comfyui.sh doctor
Step 2: install the node pack
cd data/custom_nodes
git clone https://github.com/bjarkebolding/bolding-comfy
cd ../..
Step 3: download the models
Nine files, about 59 GB. Paths are relative to data/models/.
ACE-Step 1.5 (the song)
File Size Directory
acestep_v1.5_xl_base_bf16.safetensors 9.3G diffusion_models/
qwen_0.6b_ace15.safetensors 1.2G text_encoders/
qwen_4b_ace15.safetensors 7.9G text_encoders/
ace_1.5_vae.safetensors 322M vae/
All from https://huggingface.co/Comfy-Org/ace_step_1.5_ComfyUI_files, under split_files/.
LTX-2.3 (the video)
File Size Directory
ltx-2.3-22b-dev-fp8.safetensors 28G checkpoints/
ltx_2.3_22b_distilled_1.1_lora_dynamic_fro09_avg_rank_111_bf16.safetensors 2.6G loras/
gemma_3_12B_it_fp4_mixed.safetensors 8.8G text_encoders/
ltx-2.3-spatial-upscaler-x2-1.1.safetensors 950M latent_upscale_models/
The checkpoint is from Lightricks/LTX-2.3-fp8, the upscaler from Lightricks/LTX-2.3, the LoRA and text encoder from Comfy-Org/ltx-2.3 under split_files/.
Step 4: start ComfyUI, with one flag
./spark-comfyui.sh service --no-bf16-vae
Do not skip that flag. LTX-2.3’s audio VAE never casts the incoming waveform to the VAE dtype, so under --bf16-vae every audio workflow dies with:
Input type (float) and bias type (c10::BFloat16) should be the same
This is not specific to my nodes. It breaks the stock ComfyUI LTX-2.3 audio templates and even a plain LoadAudio node. --no-bf16-vae takes only the VAE off bf16 and keeps the unet and text-encoder speedups. Passing --fp32-vae instead does not work, because ComfyUI’s VAE precision flags are mutually exclusive and one has already been added by then.
UI is at http://<spark-ip>:8188.
Step 5: run the workflow
Load example_workflows/audio_driven_music_video.json from the node pack. It ships complete with a working song and shot list, so you can hit Run first and read the graph afterwards.
Two nodes are the ones you edit, both marked in the workflow:
TAGS + LYRICS feeds ACE-Step. Style tags, then lyrics with [Verse], [Chorus] section markers, plus BPM, key, language and duration. The sampler runs 50 steps at cfg 6.0, euler/simple, flow shift 3.0.
SHOT LIST drives the video. Timestamped prompts, one per shot:
[0:00]        change the prompt, keep the frame chain (a move within a shot)
[0:16 cut]    break the chain, a real scene change
[0:48 back]   resume from the anchor, the last frame before the cutaway
back is what makes cutaways affordable. The anchor deliberately does not advance through a cut, so your singer comes back looking like herself instead of like a different person.
There is an optional reference image input for a character or location.
Set segments to ceil(song_seconds / seg_secs) and you are done. The example is 37 segments of 4 seconds for a 2:28 song.
Watching it run
./spark-comfyui.sh status --watch 3
Heat-coloured sparklines for temp, power, clocks, unified memory, plus live it/s and a per-session summary. Every sample also goes to a log file, which is the point: if your unit is one that hard-reboots with no logs on a power spike, the trail survives. tune --clock-cap 2100 fixes that class of reboot, since nvidia-smi -pl is not available on GB10.
Links
Happy to answer questions on any of it. If something fails, doctor output is close to a complete bug report on its own.
This is awesome man, thanks! I have gotten comfy setup and working well so I am definitely going to give this a shot. Too cool
