Dear Nvidia Team
We are trying to understand the ACOK circuit on the P3737-A04. As we are not able to find a datasheet of the GS7155NVTD-R, maybe you can help us:
- Do we assume correctly that the POK signal (PS_AQR_PG) is an open-drain output and can only pull to GND?
- With the Jumper of the ACOK_CON in place, this signal gets pulled-up to 3V3_AO? Or what is exactly the signal CCG4_LED (I2C_INT_AR of the USB PD Controller)?
- If we would not need WOL, could we just use a pullup on P0.6 of the Button MCU or do we still need the whole ACOK_CON_RISING Circuit?
Thank you for your help.
Best regards
