Platform & Software
Board: Jetson Orin NX 16GB
JetPack: 5.6 / L4T R35.6
OS: Ubuntu 20.04
WiFi chip: Intel Wireless 8265/8275 (
lspci→0001:01:00.0 Network controller: Intel Corporation Wireless 8265 / 8275 (rev 78)) -
Kernel driver:
iwlwifi -
NetworkManager: 1.22.10
wpa_supplicant: v2.9
Problem
Attempting to create a WiFi hotspot/access point via NetworkManager fails immediately and consistently. The SSID never becomes visible to any scanning device. This occurs whether using the nmcli device wifi hotspot shorthand or a manually constructed connection with mode ap + ipv4.method shared.
This is needed for field robotics use — the Jetson needs to act as a WiFi AP with no infrastructure network present.
Command and Error
$ sudo nmcli device wifi hotspot ifname wlan0 ssid WEED_ROBOT password weedrobot
Error: Connection activation failed: (11) 802.1X supplicant took too long to authenticate.
Root Cause Identified in Logs
journalctl -u wpa_supplicant shows the actual failure happening 3 seconds into the 25-second NM timeout:
wlan0: CTRL-EVENT-DISCONNECTED bssid=... reason=3 locally_generated=1
Note: nl80211 driver interface is not designed to be used with ap_scan=2; this can result in connection failures
wlan0: Failed to start AP functionality
journalctl -u NetworkManager confirms NM successfully builds the AP config and passes it to wpa_supplicant, but then times out:
Config: added 'ssid' value 'WEED_ROBOT'
Config: added 'mode' value '2'
Config: added 'frequency' value '2412'
Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
device (wlan0): Hotspot network creation took too long, failing activation
device (wlan0): state change: config -> failed (reason 'supplicant-timeout')
NM is passing ap_scan=2 to wpa_supplicant when activating AP mode. The iwlwifi/nl80211 driver rejects this immediately. NM then times out after 25 seconds and surfaces the misleading 802.1X error message.
What I’ve Already Verified
iw list confirms AP mode is supported:
Supported interface modes:
* AP
* AP/VLAN
Supported commands:
* start_ap
Valid interface combinations:
* #{ managed } <= 1, #{ AP, P2P-client, P2P-GO } <= 1, #{ P2P-device } <= 1, total <= 3, #channels <= 2
rfkill list all — no soft or hard blocks:
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
No ap_scan override anywhere in /etc/wpa_supplicant/ or /etc/NetworkManager/ (only an unrelated reference in functions.sh for wired 802.1X).
No global /etc/wpa_supplicant/wpa_supplicant.conf exists.
wpa_supplicant is running in userspace socket mode (-u -s), not with a config file.
Things Tried That Did Not Help
nmcli device wifi hotspotone-liner -
Manually creating connection:
nmcli con add type wifi ifname wlan0 mode ap ipv4.method shared wifi-sec.key-mgmt wpa-psk ... -
Adding
/etc/NetworkManager/conf.d/wifi-ap.confwith[device] wifi.backend=wpa_supplicant -
Restarting both NetworkManager and wpa_supplicant before attempting
Questions
Is NetworkManager 1.22.10 on Ubuntu 20.04 known to incorrectly pass
ap_scan=2to wpa_supplicant when configuring AP mode for an nl80211 driver (iwlwifi)? -
Is there a supported configuration to force
ap_scan=1for AP mode, or a patch/backport available for NM 1.22.10? -
Is upgrading to JetPack 6 (Ubuntu 22.04, NM 1.36+) the expected resolution, or is there a workaround on JetPack 5?
Has anyone successfully run AP mode on an Intel 8265 with iwlwifi on JetPack 5?
